Engine Fans V6
casrockbongo
Engine Fans V6
Post by casrockbongo » Thu Aug 12, 2010 10:25 pm
Is that even the right term!? Hi all. Sorry if this has been covered many times, I don't even know the correct terms to search for.
Anyway, (typing with some trepidation) since being sorted at Discount Trucks - my V6 has been running perfectly. (touch wood touch wood!)
However I was wondering if anyone could advise on whether their cooling fans run on the engine when the ignition is off? The fans on my last car would run for ages if the engine was very warm, even after I was well into the house and having a cup of tea! The Bongo is a different story - the fans only run when the ignition is on. They also click on and off with tremendous frequency.... maybe this is fine . . just wondered what other folks experience was...
Looking forward to your wise words and thanks for reading.
cozmo1589
Re: Engine Fans V6
Post by cozmo1589 » Thu Aug 12, 2010 10:28 pm
casrockbongo wrote:Is that even the right term!? Hi all. Sorry if this has been covered many times, I don't even know the correct terms to search for.
Well my V6 has one fan in engine bay which cuts in and out when required, never heard it running on after ignition was off. There is a roar of fans noise though when the climate control is on, this is seperate to the engine cooling system. Again this only come on with Aircon/Climate Control and would not run on when engine is off. Hope this helps?
ML 270 CDi
Re: Engine Fans V6
Post by missfixit70 » Thu Aug 12, 2010 10:43 pm
If you've got the ac on the rad fans will switch on & off frequently as the ac compressor loads & unloads, if the ac isn't on, I wouldn't think they should be clicking in & out like that TBH.
cheffy34
Re: Engine Fans V6
Post by cheffy34 » Thu Aug 12, 2010 11:32 pm
Well i have to confess i have had my v6 for over 3 year now and untill the last couple of months was my daily commuter in all kinds of traffic and conditions and the only time i have heard my fans on is when it stood on idle for a long time and with a mason that is about 3/4 on the guage :) maybe missfixit is onto summit with the aircon :wink:
Dar
Re: Engine Fans V6
Post by Northern Bongolow » Fri Aug 13, 2010 4:04 am
check air con is off as kirsty says.
if off, whats it had done at the garage,could be airlocked in the head/s next to the fan switch
causing a hot spot that the fans are trying to cool.
i would suggest you bleed it,is it loosing coolant,any coolant leaks.
Re: Engine Fans V6
Post by g8dhe » Fri Aug 13, 2010 9:43 am
The radiator fans only run when the Ignition is on and are then controlled by the ECU and A/C, the scavenger fan is not directly controlled by the Ignition only by the ECU and so could run on after the engine is turned off, but this only seems to come on when the engine is very hot anyway.
casrockbongo
Re: Engine Fans V6
Post by casrockbongo » Sat Aug 14, 2010 3:53 pm
Thanks for your thoughts . . .yes the air con is usually on so that is probably the fans clicking on and off. Hopefully! I doubt an airlock as the engine has been bled more times than I have had hot dinners! Going in for a service soon so will mention it to Fred then.
Thanks all!
Re: Engine Fans V6
Post by missfixit70 » Sat Aug 14, 2010 4:05 pm
Or just try turning the ac off & see if it still happens?
