leaking sky light
Geggsie
leaking sky light
Post by Geggsie » Sat Aug 21, 2010 10:38 am
I have a leak in the sky light and have tried using sealant unsuccessfully. I wonder if anyone knows of a garage in south wales area that is prepared to take it out and reseal. I tried auto glass who were to say the least unhelpful and dismissive. Any tips gratefully received
haydn callow
Re: leaking sky light
Post by haydn callow » Sat Aug 21, 2010 10:40 am
First thing I would do is try and locate a complete new seal....then armed with that it should be easy to find a fitter.
http://www.coolantalarm.co.uk
Also BMW Clocks
mikexgough
Post by mikexgough » Sun Aug 22, 2010 9:41 pm
according to the service manual it is fitted in a particular way, personally I would show an auto screen/sunroof fitter the fitting process to see if they can help....
wishmaster
Post by wishmaster » Sun Aug 22, 2010 11:31 pm
Hi Geggsie, you could try St. ilan car imports next to kwikfit in caerphilly, Steve's the man he knows bongo's inside out, he does my servicing on our V6.
Do you know there's a mini meet in Porthcawl on 5th september, av a look in the welsh section for more info. Be great to see yer there :wink:
Im in the Caerphilly area by the way :)
Izzy
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
gmaczbongo
Post by gmaczbongo » Sun Aug 22, 2010 11:38 pm
Did you use an automotive window sealant.
Sticky black stuff forced into all the joints around the window.
Does sky light=sun roof etc.
Post by Northern Bongolow » Mon Aug 23, 2010 12:43 am
theres a roof only for sale on a well known tinternet selling site,at the moment if this is any good to you its quite near to you to.
helen&tony
Post by helen&tony » Mon Aug 23, 2010 5:44 am
Are you talking about the fixed skylight in the AFT by any chance?
Geggsie
Post by Geggsie » Mon Aug 23, 2010 12:14 pm
Thanks for all the good advice (what else would I expect from this forum!). For the time being I am trying the sealant again (Recommended by a window fitter ). Judging by the weather now (it is persistently raining again!!) it should be put to a thorough test. Failing that I may well try the guy in Caerphilly. I am in Bedwas so know where you mean. As for the other responses a few questions:
Where can I get a complete new seal
Do you have a copy of the manual which shows the fitting
Unfortunately I can't make Porthcawl on the 5th
Geggsie
Post by Geggsie » Tue Aug 24, 2010 12:42 pm
Yes it is an AFT
Triple/R
Post by Triple/R » Tue Aug 24, 2010 12:49 pm
The sealant used on caravans is Silkafix (i think) people reckon it's far superior than normal sealants~should get it from any local caravan supplies.
Regards Ray & Christine
