can some one tell me what the tire/wheel diameter is on a standard bongo so i can work out the circumference to check against mine (ail wheels) as speedo is well out.
cheers
wheel size
soulpaul
- You've Been Bongod
Re: wheel size
they should be either 195/70/15 or 215/70/15 if standard size
David Edwards
Re: wheel size
mine are 215 x 65 x 15 al round.
soulpaul
Re: wheel size
sorry i did'nt make it clear what i what is the measurement of the wheel overall (ie not 15 inches but the wheel with standard tires fitted ) so if some one can run a tape over one that would be great.
Re: wheel size
Just put your tyre sizes here and you'll have your answer
http://www.tyresave.co.uk/tyresize.html
soulpaul
Re: wheel size
cheers john i will try the site
