Sloooow
Badmiker
Sloooow
Disaster!
Well, a worry at least; the Bongo seems to be losing power. The engine wont rev freely above 3k so when accelerating, if the box drops a gear, the engine just roars and we start slowing down. It takes a real effort to nurse her up to speed.
There's no smoke, white black or blue, there fluids seem fine, I've cleaned the banjo filter (the ball end of the allen key is ideal for extracting it BTW), and the fuel consumption doesnt appear dramatically terrible.
Help?!
Help?!
Re: Sloooow
Check to see if the big wide bore (turbo?) hose hasn't come lose to the right of the picture...? (Not my engine pic.) I had something similar...
Badmiker
Re: Sloooow
The dirty black one behind the blue (samco?) hoses?
Re: Sloooow
Yep! On the elbow... Mine came off & was hard to spot.. Quick re-afix & it was sorted for me!
Re: Sloooow
I'm no expert.. But the turbo bit in this thread may help too....
http://www.igmaynard.co.uk/bongo/forum/ ... urbo+clamp
Which is what i thought may have happened to mine initially, that's why i didn't spot the lose hose on the front in the first picture when i first lifted the seats in a lay-by.. (That, & on the second inspection the hose may have dropped down a little further making the disconnection more prominent.)
... Well that & praying it wasn't gonna set me back a new turbo..
It can really feel the weight when disconnected!
Re: Sloooow
might sound dumb but....you havent got the hold button pressed in??
if not that check the level in the autobox, dip stick under drivers seat?
Then start looking for engine/turbo problems, good luck
springer
Re: Sloooow
Mine had a go sloooooow after going in for new cylinder head
Turns out it was just a vacuum hose ? 2 minute fix, worked a treat.
Badmiker
Re: Sloooow
Great advice, thanks. Finally got a chance to have a proper look under the seats. I thought I had noticed some wetness around the hose mentioned and, sure enough, it's damp around that connection and around the turbo-intercooler connection.
For future searchers, this page:
http://www.igmaynard.co.uk/bongo/fox_archives7.htm
identifies the problem.
I tightened the clamps up and it's running better; revving to around 3.5/4 and holding 55ish uphill but it's still a bit erratic; sometimes it loses power when it drops a gear. What kind of performance can I expect; what's a typical top speed, and what's a typical up-hill speed?
I checked again this morning and thought I could get a bit more on the clamps. Unfortunately I couldnt; I now need a couple more clamps. Doh! 'Mikalor W4' are the strongest I can find.
It's going back to MVM, where I bought it, this weekend for a look over. I'm pretty sure it's the clamps; I suspect they were replaced when it had it's belts changed but it's still under warranty so I'll let Charlie have a look. I might be tempting fate but I've got nothing but good things to say about MVM (Manse Vehicle Management). Charlie is very straightforward to deal with and seems very fair and honest. He normally has a couple of Bongos in stock too.
Badmiker
Re: Sloooow
Dont want to seem to be talking to myself, but...
Gotta recommend MVM to anyone in the area looking for a Bongo. They have been an absolute pleasure to deal with and have gone out of their way to make sure that everything has been good for me. As soon as I said there was some problem the Bongo was booked into the workshop with parts waiting, despite them having more than enough paying work on! End result of above problem was a replaced fuel filter and problem solved, (Dougie, mechanic at MVM, didnt seem to think much of 'loose hoses' as an issue.)
- gmaczbongo
Re: Sloooow
I think it will be the fuel filter that is causing the problem.
Oops you have already done this.
- dandywarhol
Re: Sloooow
You sure you haven't been playing with the engine quick warmup switch to the right of the steering column? Or cut of your nippers fingers if they've been mucking about - you were warned y'know!
Badmiker
Re: Sloooow
They're quite quick when they can get enough fuel, arent they?
Oddly enough, inspite of the fuel effectively having a 'gastric band', I didnt notice it drinking any less fuel. Suggests that the engine is equally (in)efficient throughout the rev range.
Re: Sloooow
The engine was likely out of the zone where the turbo gives boost, so it was operating outside of its most efficient band, so you had less performance but the same fuel consumption.Badmiker wrote:They're quite quick when they can get enough fuel, arent they?
When asked about Western Civilisation, Ghandi said 'that would be a good idea'...
- dandywarhol
Re: Sloooow
Did you check the engine warm up switch wasn't inadvertently flicked on?????Badmiker wrote:They're quite quick when they can get enough fuel, arent they?
They've been known to stick closed even if the switch is turned off - a partially closed exhaust flap (which the switch operates) will give performance issues - best check it out...........
Badmiker
Re: Sloooow
Switch was definitely not on, and has been left well alone!
I'm confident that the problem was with the fuel filter. The car must have been getting gradually worse, slow enough not to be noticeable; the change in performance when the filter was replaced was quite dramatic! Felt like a damn ferrari... well, it is mid-engined....
