Bought one of those BMW clock/ radio blanking space thingies off ebay. Previous threads have given me what the wiring colours are - people also said you can pickup these feeds from the back of the radio.
Now my radio runs off the leisure battery, which is fine for the clock itself, I guess, but I want the backlight to come on with the lights. My radio is lit all the time, (except when you remove the face-plate).
Can anybody suggest where to get a feed that is switched with the lights, reachable from the radio hole, that I can get a scotchlok connector onto? Colour?
Clock backlight feed
trevd01
- dandywarhol
Mark & Shelly
tonyp
ISO plug A pin 6 is "illumination", this is the connector that plugs into the back of most radios. On my connector the wire is orange. I checked mine with a voltmeter and it goes to 12V when the lights are on. If you do a search with your favourite search engine you should be able to find a diagram of the ISO connectors, there are 2 (A and B) although on mine they are in one moulded block.
