Cracked rear lens
Distilled Waters Run Deep
Cracked rear lens
Post by Distilled Waters Run Deep » Fri Sep 03, 2010 6:14 pm
Clumsy... I opened a gate onto one of the rear lights & cracked the red reflector, & a piece fell inside -I reckon a bit of araldite wouldn't be amiss... I've removed 3 tiny screws from inside the cluster black body, & I can see some red tabs as well as clear ones. Before I get heavy-handed, has anyone opened one up before & could give me a tip or 2?
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
Re: Cracked rear lens
Post by bigdaddycain » Fri Sep 03, 2010 11:51 pm
I'd go slowly with it... I wasn't aware the rear light clusters could be taken apart? :shock:
Post by Distilled Waters Run Deep » Sat Sep 04, 2010 10:21 am
I'll find out, BDC!
Seeing as the tabs are likely to be clips, I've pushed a bit -but it's all been watertight for 13 years now... I'll try some gentle heat, maybe a bucket of hot water, to see if that softens the black plastic & any seal which may be on there. Will let you know how I get on...
Post by Distilled Waters Run Deep » Sat Sep 04, 2010 12:50 pm
Well I gave up on that -if I'd pushed any more I fear I'd've been looking at a shattered jigsaw beyond an hour with a lot of araldite -& I glued the piece back through the bulb-socket. Once it's hardened a bit, I'll add another layer & try to polish up the streaks. Not exactly concourse, but it shouldn't look too bad...
[img][img]http://farm5.static.flickr.com/4106/495 ... 053542.jpg[/img]
Botched Bongo lens -stage 1? by McFuzzi, on Flickr
[/img]
Last edited by Distilled Waters Run Deep on Sat Sep 04, 2010 12:55 pm, edited 1 time in total.
dave_aber
Post by dave_aber » Sat Sep 04, 2010 12:53 pm
Doesn't look too bad.
p.s. You pasted too much in from flickr inbetween the IMG headers. You just need the bit after "img%20src"
img%20src="http://farm5.static.flickr.com/4106/495 ... "%20width="
..............^------------------------------------this bit---------------------------------^
Picasa does the same, I just paste it all in then delete the bits you don't need.
Image...Image
Post by Distilled Waters Run Deep » Sat Sep 04, 2010 12:58 pm
Thanks -maybe I'll finish fixing the gate before I finish that then, to make sure it doesn't happen again... :wink:
Post by Distilled Waters Run Deep » Sat Sep 04, 2010 1:01 pm
p.s. Dave, how did you do all that editing & tell me how to do it before I'd even finished looking at it?
Ah, you must be a real supreme being...
dave_aber
Post by dave_aber » Sat Sep 04, 2010 1:12 pm
Just a geek.
(You need to delete the first IMG and the last /IMG)
Image...Image
Post by Distilled Waters Run Deep » Sat Sep 04, 2010 1:24 pm
I've tried again with the pic -I guess I'm the other binary...
