And Dave already had the correct spigot rings fitteddaveblueozzie wrote:I went to Wheelquick at the weekend to have new tyres on the bongo, Stu said i have the wrong nuts to hold the wheel correctly, I told him Ive had the wheels balanced 4 or 5 times to try and cure the steering wheel wobble to to avail, He got me the correct wheel nuts and not had any wobble at any speed since then, so check your nuts.
Steering Wheel Shake and kick back on brake pedal
Re: Steering Wheel Shake and kick back on brake pedal
				celtictigress
				Mark Norton
 - Bongonaut
Same problem with the Mazda wheel nuts, swapped for aftermarket mushroom shaped nuts to cure the wheel shake.
				celtictigress
Yeah I think I need to get the nuts changed as the spigots (correct size lol) have been fitted but I'm still getting that shake. I'll need to get it along to an alloy wheel place because I've no idea what nuts to use other than the fact that they should be 21mmMark Norton wrote:Same problem with the Mazda wheel nuts, swapped for aftermarket mushroom shaped nuts to cure the wheel shake.
				MountainGoat
Steviebongo in Glasgow who now sadly is selling his Bongo for family reasons was selling wheel chromium wheel nuts not long ago (I bought some off him at the Scottish Bash). I suggest that you get in touch with him if you can and see if he has any left if they are suitable.
I can PM you his mobile number if you need it.
Tony
Tony
Former SGL5 Owner Jeep Cherokee 2.5CRD  Burstner Ixeo Time it585
				celtictigress
MountainGoat wrote:Steviebongo in Glasgow who now sadly is selling his Bongo for family reasons was selling wheel chromium wheel nuts not long ago (I bought some off him at the Scottish Bash). I suggest that you get in touch with him if you can and see if he has any left if they are suitable.
Tony
Cheers, I'll PM him in the first instance and see how I get on
