Is this the fog light block connector?
Alifriendee
Post by Alifriendee » Tue Sep 14, 2010 4:22 pm
Delving behind the fuses under the dash last weekend I happened upon this block.
A previous owner has cut one of the wires behind the block and used it for the aftermarket fog light power supply.
Does anyone know what this is intended to be connected to and where the wires ultimately end up? It will be handy if this is the wiring for a fog light so I can use an official Mazda fog light switch and for the wires to end up down the back of the vehicle somewhere near where my fog light is located.
The wiring currently used for the aftermarket fog light is domestic lighting cable. Very unsuitable I guess.
Many thanks in anticipation.
Nick
lpgimports
Re: Is this the fog light block connector?
Post by lpgimports » Tue Sep 14, 2010 4:25 pm
Its likely wiring for a pair of front driving lamps, some have plug for this, and there must be plugs at the front somewhere for looms for the driving lamps. There is no rear fog lamp wiring in the Bongo.
Paul
gmaczbongo
Post by gmaczbongo » Tue Sep 14, 2010 8:23 pm
You should still be able to use the mazda switch as long as it has a bulb in it.
Or you need some other means of showing fog lights are on.
Just chop into the already chopped new fog light wiring.
As long as the power wire is insulated, the domestic stuff will be ok.
Post by g8dhe » Tue Sep 14, 2010 10:17 pm
The front fog light connector is marked E2-01 in the diagram below, if you look below the diagram there are diagrams of each connector along with the wiring colours used;
Alifriendee
Post by Alifriendee » Tue Sep 14, 2010 11:03 pm
Many thanks.
