Ignition fault?
georgey
Ignition fault?
Post by georgey » Sun Sep 26, 2010 6:15 pm
Hi guys, on turning ignition key on in Bongo (diesel) it doesn,t start every time only happening last couple of days....turn ignition key and there is just a click from under drivers seat, I assume that is where the solonoid is, has anyone got any ideas? any help appreciated...regards Geoff aka Georgey...
gmaczbongo
Re: Ignition fault?
Post by gmaczbongo » Sun Sep 26, 2010 7:10 pm
Sounds like a solenoid problem.
Power must be getting to the starter as it is clicking.(assuming that is where the click is from)
First thing is to check all cables are tight.
Then check voltages with volt meter.
Then bench check the starter for proper operation.
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: Ignition fault?
Post by M 80NGO » Sun Sep 26, 2010 7:16 pm
Check the battery connections are good clean and tight as it only takes a slightly loose terminal to cause problems, if all is ok there then its a starter solenoid issue, good luck and keep us updated. :wink:
georgey
Re: Ignition fault?
Post by georgey » Sun Sep 26, 2010 7:53 pm
Think I,m gonna pop the starter off and check it and change the contacts...hopefully this will cure it....Fingers crossed....Thanks for the swift replies...
wormey
Re: Ignition fault?
Post by wormey » Sun Sep 26, 2010 8:32 pm
Before you get to deep, check the earth on the glow plug relay which is under the bonnet, top left corner under a plastic cover.
There are four connections (wires) on the bottom, two large, two small.
The two small ones, one is live when you switch on the ignition, the other is an earth. On this one, run a temp earth wire to the chassis and see if that works.
I do have some photos of all this, I have yet to put them on photo bucket.
I can email them to you if you pm your email address.
My freda wouldn't start easily, no power to the glow plug rail. all sorted now.
Daz, :D
Daz and debs
wormey
Re: Ignition fault?
Post by wormey » Sun Sep 26, 2010 11:16 pm
Email sent, read PM first. :roll:
Daz and debs
georgey
Re: Ignition fault?
Post by georgey » Wed Sep 29, 2010 12:35 pm
All fixed....was the contacts in the starter motor they were well worn...easy fix got repair kit and instructions from http://www.repairkitsuk.com/4.html.....very good service and all for £13 delivered...Regards Geoff...
wormey
Re: Ignition fault?
Post by wormey » Wed Sep 29, 2010 5:41 pm
Good news, :D
Daz and debs
