sun roof
longhaul8
sun roof
Post by longhaul8 » Sat Oct 02, 2010 1:57 pm
Hi my sun roof has decided not to play today it wont open just off to investigate but are there any common faults to look for ?
and as you will have all guess it is a tintop.
steve
Re: sun roof
Post by g8dhe » Sat Oct 02, 2010 2:12 pm
I think you will find Jaylee has played quite a bit with his, the fuse however is this one;
jaylee
Re: sun roof
Post by jaylee » Sat Oct 02, 2010 3:08 pm
I have indeed..! :D Fitted a second switch up front for ease of use..
Are you getting any whining from the SR motor with the glass struggling..? if so, pull back the sun shade bit (it will lighten the load.) & lube the runners with some kind of lithium grease...
If the fuse is OK & there is no electrical activity at all..? Remove the rocker switch, unplug, its easy to take apart, but do it on a surface so you cant lose anything.. Then clean the contacts inside the switch.. You will see four poles.. They some times crud up with what i call mouse mung, like the stuff in the old roller-ball computer mouse.. Clean where it touches the two metal rocker bits too, plus the bend where it sits in the cradle & the the two coppery coloured cradles as well... Its a bit of a fiddle. Dont worry about the grease on the top of the metal part that lubes the action from the plastic spring loaded pushes at the bottom of the actual switch!
I forgot to add clean em with a bit of fine grade wet & dry...
Good luck!
longhaul8
Re: sun roof
Post by longhaul8 » Sat Oct 02, 2010 4:48 pm
Hi i check the fuse first and this is fine even though for some reason mine has a 20 amp and not a 10 as in the picture but that should make no differance.
So then on to removing the switch and cleaning it done that but still nothing no noise at all from the motor.
check there is a live feed to the switch and i have one live feed.
so i am thinking the next course of action is to use a bridge wire to see if the sun roof will open and if it does that must lead back to the switch.
Good idea or what ?
steve
longhaul8
Re: sun roof
Post by longhaul8 » Sat Oct 02, 2010 4:50 pm
sorry my eye sight is bad 30amp in pic
Steve
rita
Re: sun roof
Post by rita » Sat Oct 02, 2010 5:28 pm
longhaul8 wrote:sorry my eye sight is bad 30amp in pic
Steve
20 amp for sun roof
30 amp for aft..
Re: sun roof
Post by g8dhe » Sat Oct 02, 2010 5:46 pm
rita wrote:20 amp for sun roof
30 amp for aft..
Yes that was my error, its the one fuse in the Bongo that has two possible values :-(
jaylee
Re: sun roof
Post by jaylee » Sat Oct 02, 2010 6:03 pm
The two metal rockers in the switch have a slight bend where they pivot see saw style.. (same as the front blind switch) It also acts as an earth point to the cradle? Did ya clean there too?? Could be bad earth in the switch? :idea:
Hope you don't mind me asking...? :oops: :wink: :D
longhaul8
Re: sun roof
Post by longhaul8 » Sat Oct 02, 2010 6:12 pm
Nope don't mind you asking at all. yes i did clean there stripped out the switch light wet ant dry to all contact points and a quick spray with switch cleaner for good measure.
still nothing but i have one live fit to the plug that the switch fits in to.
longhaul8
Re: sun roof
Post by longhaul8 » Sat Oct 02, 2010 6:48 pm
well looking on the bright side it is one of those rare accasions here in norfolk it's raining ..........lol
At least my sun roof is stuck in the closed position.. :D ..
