Injectop Pump Stop Valve
The Great Pretender
Post by The Great Pretender » Sat Oct 16, 2010 1:55 am
Being lazy really, :lol: Anyone know how far the plunger moves between open and closed?
To infinity and beyond
roofraisers
Re: Injectop Pump Stop Valve
Post by roofraisers » Sat Oct 16, 2010 2:34 pm
About 3mm or 1/8" old money if I recall correctly.
If you remove the valve from the pump & put a live to it whilst earthing the valve body you should see the plunger kick in & out. Check for muck in the general solenoid valve area including on top of the rubber plunger in between the coil spring & look to see that rubber is smooth & uniform in shape, not worn, ragged, oval etc. if you are having intermittent stop/ starting issues.
Nigel
The Great Pretender
Post by The Great Pretender » Sun Oct 17, 2010 12:10 am
Thanks for the info. :wink:
mikexgough
Post by mikexgough » Sun Oct 17, 2010 9:13 am
321Away
Post by 321Away » Sun Oct 17, 2010 1:15 pm
Absolutely astounds me the money Mazda charge for these, its like £200+, its nuts,the cut off solenoid is exactly the same as Ford fit to the escort vans etc and are widely available all over Ebay etc for about the £10, I recently found a supplier who's units have a Hex shaft which means even less contact area thus less likely to ever stick.
Julian
The Great Pretender
Post by The Great Pretender » Mon Oct 18, 2010 12:32 am
Thanks again, I don't have a problem with my pump. The reason for asking was for an idea I have to use a solenoid to operate 4 valves. :wink:
Bloody sites playing up again, not notifying me of posts. :evil:
