Tailgate Door Card Removal ????
Dr.Jekyll
Post by Dr.Jekyll » Sun Oct 17, 2010 5:06 pm
OK - now I am banging my head as I just can't get the door card off the tailgate. I have removed the grey pop-plug-holder things etc but just can't get the card off. I have a 96 TinTop so no door opening catch to worry about on the card. The remaining "hidden" clips are so tight the cardboard is comming off. Any tips? Thanks.
Dr.J
mwnci
Re: Tailgate Door Card Removal ????
Post by mwnci » Sun Oct 17, 2010 5:42 pm
im having the same problem
if you manage to do it- you can come help with mine :wink: :wink:
rita
Post by rita » Sun Oct 17, 2010 6:06 pm
HI,It looks like you need one of them fork type trim remover tools..
http://www.lushprojects.com/bongopartsm ... no=.html#8
wormey
Post by wormey » Sun Oct 17, 2010 6:21 pm
I used a small screw driver to initially get the middle of the plastic trim clips up and then used a a pair of small pliers behind to even the pulling out.
Beneath the card is a plastic sheet around the metal rim thats black goo ed on, very messy.
Hope this helps. :D
Daz and debs
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Post by M 80NGO » Sun Oct 17, 2010 6:25 pm
I had my inner panel off on friday night if all the grey pegs are out then push from the bottom of the panel up and it should slide off the locating clips :wink:
