Driving home on Friday I noticed the needle just start to rise on the temp guage. Pulled over straight away, and discovered that I had virtually no coolant left in the tank. Managed to get hold of warm water to refill with, filled the tank and let the air out, and then drove carefully home. Discovered a drip from somewhere under the drivers side, so waited until today to drive carefully back into town to the garage, having topped up the water tank over the weekend to keep it full.
Garage found a small bore hose under the drivers side leaking, and we established that it was the connection and not the hose itself. He trimmed the end and put it back on, tightened the clamp, but has advised replacing the hose in case it is worn inside - we couldn't see any reason for it to start leaking.
First question is should I just replace all the hoses at this time? It might be worth mentioning that when I checked the hoses in the light on Saturday the one coming from the tank seemed to be crunchy as if there were crystals inside, but it wasn't cold enough for it to be frozen. This did ease as the water warmed up with the engine running.
Second question (bear with me) is when I refilled the tank I wasn't able to follow all the steps, given that it was dark and I didn't have any instructions with me, even if I understood them! So I followed instructions over the phone from my dad, who advised me to fill the tank, then run the engine with the cap off, which resulted in a huge amount of air bubbling out, and then I kept topping it up until it remained steady. The van has been running perfectly the whole way through, absolutely no indication of problems until the needle moved. It has run perfectly since. I will be getting the garage to replace the coolant from scratch when they change the hose/s, as per the fact sheet instructions, but will I be ok to do short journeys until then? Given that the leak should now be fixed (got to check tomorrow).
As the van is running great despite all of this, what are the chances of having done real damage, and how would I know? In case it is relevant (because I have been reading around and noticed the heaters mentioned somewhere), the heaters did stop working in the 10mins before the needle moved, but were working very well as soon as I replaced the fluid.
Obviously I also have the issue of just having water in my tank at the moment, but am going to top up with antifreeze tomorrow which should hopefully be enough to cope with possible minor frosts until it is done properly. Might wrap it up in a blanket or two as well!!
Sorry for such a long post, just trying to work out what I need to ask at the garage, what I need to buy, and what I need to be looking out for. Thanks
