no front heater
kitebongo
no front heater
Post by kitebongo » Wed Nov 17, 2010 11:24 pm
Hi All
can any one advise how to fix my front heater. The rear is ok and the air con is fine but when i crank up the heater control the blower loses it blow and can no longer defrost my cold body! this whole affair started after my new engine was fitted. Help any one
kind regards kitebongo
mister munkey
Re: no front heater
Post by mister munkey » Wed Nov 17, 2010 11:28 pm
Does THIS LINK help?
Re: no front heater
Post by Northern Bongolow » Thu Nov 18, 2010 2:36 am
can you be more specific about what is actually happening.
is the rear heater hot and the front one not?
is the front blower working?
is the front blower working but only on one, or certain speeds?
is the heater/blower working but not dirrecting where you would like it,?
have you got a modified temp gauge,or mason alarm corrected gauge,or is it sat at 11 oclock when warmed up?
wonkanoby
Re: no front heater
Post by wonkanoby » Thu Nov 18, 2010 9:05 am
do both the hoses that feed it get hot
as the radiator should be hot at all times
once the engines warmed up
if they are not it may well be blocked
kitebongo
Re: no front heater
Post by kitebongo » Sun Nov 21, 2010 11:44 am
Northern Bongolow wrote:can you be more specific about what is actually happening.
is the rear heater hot and the front one not?just warm
is the front blower working?yes
is the front blower working but only on one, or certain speeds?fine all speeds
is the heater/blower working but not dirrecting where you would like it,?directions ok
no sat at 11 when warm
cheers
maxheadroom
Re: no front heater
Post by maxheadroom » Sun Nov 21, 2010 11:53 am
as Kirsty says "Check the linkages in the drivers footwell to see if it's operating the changeover flaps"
http://www.igmaynard.co.uk/bongo/forum/ ... rm#p253285
Keep the Faith
Re: no front heater
Post by Northern Bongolow » Sun Nov 21, 2010 3:12 pm
cheers
more info needed :lol: :lol:
kitebongo
Re: no front heater
Post by kitebongo » Fri Nov 26, 2010 7:31 pm
maxheadroom wrote:as Kirsty says "Check the linkages in the drivers footwell to see if it's operating the changeover flaps"
Hi Thanks
all the linkages work!
kitebongo
Re: no front heater
Post by kitebongo » Fri Feb 04, 2011 7:41 pm
Hi Thanks
Still cold, but the summer is on its way.
Some one said the heater matrix may be blocked!
This problem started after my engine was replaced.
Can any one explain how to bleed the heater matrix?
Re: no front heater
Post by francophile1947 » Fri Feb 04, 2011 8:06 pm
kitebongo wrote:Can any one explain how to bleed the heater matrix?
You can't - it gets bled at the same time as the cooling system 8)
You still haven't answered if both hoses to the heater matrix get hot - it's hard to help if we don't know that #-o
kitebongo
Re: no front heater
Post by kitebongo » Mon Aug 29, 2011 1:04 am
happy warm days ! heater fixed. I took off the fan and the front cover to the air con which expose the two front heater matrix pipes. then flushed it out using a garden hose. This forced out all the brown slug until it ran clean water. No more cold in the snow. Aso just had the air con regassed, The rear is ice but the fron is cool. i supect warm are is still mixing with the air con.
jaylee
Re: no front heater
Post by jaylee » Mon Aug 29, 2011 8:43 am
kitebongo wrote:happy warm days ! heater fixed. I took off the fan and the front cover to the air con which expose the two front heater matrix pipes. then flushed it out using a garden hose. This forced out all the brown slug until it ran clean water. No more cold in the snow. Aso just had the air con regassed, The rear is ice but the fron is cool. i supect warm are is still mixing with the air con.
You may just need to ajust the cable that goes to the heat control flap..? (On th passenger side foot well.)
Check this out too, i can help/improve air flow a great deal...! http://www.igmaynard.co.uk/bongo/forum/ ... olive+fork
