replace cv boot
Germarchip
replace cv boot
Post by Germarchip » Sat Nov 27, 2010 12:37 pm
how do you go about replacing the outside CV joint gaiter ? Is there a circlip in there or do you just need to hit it with a mallet ?
rita
Re: replace cv boot
Post by rita » Sat Nov 27, 2010 1:51 pm
Germarchip wrote:how do you go about replacing the outside CV joint gaiter ? Is there a circlip in there or do you just need to hit it with a mallet ?
Hi both,
......http://www.lushprojects.com/bongopartsm ... mgno=.html
Cheers.
321Away
Re: replace cv boot
Post by 321Away » Sat Nov 27, 2010 3:35 pm
BIG mallet!! you'll hit your hand a few times, they either come off nice or they're a right pain, sometimes you'll dislodge the inner joint so in the near side case be ready to put it back in quickly or you'll lose a portion of your front diff fluid.
Julian
helen&tony
Re: replace cv boot
Post by helen&tony » Sat Nov 27, 2010 3:49 pm
To avoid splitting the inner one, grip the shaft with a large set of stilsons, and wedge against something to prevent it moving, and wallop the outer...
kawasaki kid
Re: replace cv boot
Post by kawasaki kid » Sat Nov 27, 2010 4:55 pm
Make sure there are no young children around as you will use lots of swear words to get it to move. :oops: The biggest problem I had was the splines on the driveshaft had seized into the hub -with rust :evil: they must not have have any grease on the production line when they assembled them. #-o I had to do both sides - oh what fun you can have with a 5lb lump hammer. :(
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
