Changed Brake Pad Problems
I have just spent the last few hours changing the front brake pads, so just took it the van out for a run to try everything out, and the brake pedal first press goes almost to the floor then second press you get good brakes, the same thing happens each time you press the brakes, even if you have just done it 10 seconds before.
Anybody have any ideas what would be causing this
G
G
Re: Changed Brake Pad Problems
Hi G,wattg wrote:Hi
G
It sounds like you have a non return valve sticking in the master cylinder,or you have somehow let air into the system.
I forgot to add that whilst pushing the pistons back in to get them past the new pads some brake fluid came out past the seal round the piston
Hi sounds like you could have drawn air into that caliper,try bleeding it,but if it is still leaking replace it.wattg wrote:I forgot to add that whilst pushing the pistons back in to get them past the new pads some brake fluid came out past the seal round the piston
Cheers..
Did you loosen the top of the master cylinder before pushing the pistons back in?
Agree it sounds like air in the system, but very unusual to have leakage from the seals.......
When asked about Western Civilisation, Ghandi said 'that would be a good idea'...
renegade
Hi there,
it does sound like air in the caliper, also, not sounding like i"m teaching you to suck eggs, new brake pads can make the brakes feel a tad spongey until bedded in
BongoMTBer
If the piston came out at all, you will almost certainly have got air in. A bleed and top up will sort it. Easy fix
You will probably get away with just bleeding the side that leaked but you may wish to take the opportunity to pump some fresh fluid through the system.
Yeah did a bleed and thats it all fixed and ready for its MOT.
Thanks all for the replies
I'd be concerned that you lost fluid around the piston seal!
Julian
Julian
