Rubbish headlights Q
Khani
Hello there folk, I'm new here so be gentle with me, had my Freda four years now and been all over the EU and UK with no probs but I've now got a couple of niggles to sort out, fuel gauge has stopped working so I've read the clinic bit and will be having a go at the weekend but my headlights seem to give about two whole candlepowers worth of light, I've read about the bulbs not being fully fitted but having checked them they seem to be fitted ok, the headlights have gone a bit yellow but passed the mot ok any ideas please?
It's a P reg, rwd 2.5d version if it matters, cheers peeps
Re: Rubbish headlights Q
t cut or gentle metal polish,rub and rub
be careful though the lenses are plastic.it will come off eventually.then fit osram night breaker bulbs
Hi guys,A pal of mine had problems with tarnished head lamp lenses.
He told me he cured it by using bicarbonate of soda and a nylon scourer.
He then applied Crystal Disc cd repair fluid using a soft cloth.
He said it restored them like new and will probably stop the yellow coming back,as they are now protected by the Polymer in the cleaner.
Ps he also said,that the tarnishing is caused by the UV coating wearing off.
Cheers Mal..
Cheers Mal..
Khani
Cheers, rub the inside or the outside?
Outside
Khani
Thank you kind sir
This stuff will sort it out: http://www.igmaynard.co.uk/bongo/member ... m#Exterior
I used some toothpaste that I didn't particularly like the taste of.
It works like jeweller's rouge and cleaned off the yellow tint.
Frank
Frank
They flew, I took up naturism
I cleaned up my headlight with Xerapol this weekend got them crystal clear, then fitted Lidl h4 +50% bulbs massive improvement. Both Xerapol and the Lidl bulbs recommended by good peeps on this forum, well impressed.
it must work ian,its recomended by bongo Gury membersIan wrote:This stuff will sort it out: http://www.igmaynard.co.uk/bongo/member ... m#Exterior
Khani
SUCCESS!!!!! Fixed my fuel gauge this morning using the helpfull destructions off here
The tealight powered headlights are next tomoz
Thanks for all your replies
top bunch
Glad you got your fuel gauge working.
Onto the lights, got a question: are they yellow because the lenses have a yellow tint, or because the bulbs are dim?
If the latter then you need to look at the wiring. Had an old car that did that and it turned out the wiring had degraded. Try cleaning the lenses first, then checking all the electrical connections are tight and clean, then maybe better bulbs (opinions vary here but I've found Osram Nightbreakers to be much better than standard).
Hope this helps.
Andy
Hope this helps.
Andy
apole wrote:Glad you got your fuel gauge working.
Hope this helps.
Andy
The lenses have a plastic coating over the lenses that's a uv coating, it goes yellow after a while and starts to peel off, the actual lenses are ok under neath the coating its just the plasic covering thats on the head lights, I had a go at sorting mine a ferw months back using some rubbing compound, didnt work to well so gave it up as bad job, might try the Xerapol when the weather gets a bit warmer
Khani
The lens's definatly have a yellow tint to them, I'm gonna try and give em a seeing too tomorrow, thanks for everyone's help
I'll be back
I'll be back
Khani
Update again, done the headlights with some T cut and a small drill with a polishing wheel, come up like new
happy days
