1. Remove the head and get it sorted at collosal expense.
2. Leave it and run on 3 good plugs.
3. Attempt to remove the remaining bit with some form of tool.
Now I have had a degree of success in the past using easy outs to remove snapped bolts from all previous problems. My only major concern is can the lower part of the glow plug drop out into the cylinder? As this would mean step 1 has to be employed. There is quite a bit of plug still protruding from the head but the main problem is getting something in to get a good hold on it. Also it is only a mil or so thick so using some grips on it would probabl just mangle it.
As it looks I reckon my best bet is to either leave it or try using an easy out, so long as the plug end won't drop into the cylinder!!
