transfer box
transfer box
hi will a 95 transfer box fit a 97 bongo, any help appreciated. thanks
accrag.
Re: transfer box
Hi,acording to the parts list its the same box from 1995 to 2001..accrag wrote:hi will a 95 transfer box fit a 97 bongo, any help appreciated. thanksaccrag.
part no 17-900..
Cheers.
Re: transfer box
many thanks, just to make sure its the box in the middle where the props meet, am i right on this.
- missfixit70
Re: transfer box
Have a look on lushprojects for yourself - http://www.lushprojects.com/bongopartsmk2/
Re: transfer box
Hi accrag,
Have you checked the box for oil,does the knocking go away if you put the box in neutral while you are traveling (IE free wheeling)?
Cheers..
Cheers..
Re: transfer box
HI YES PUT OIL IN REAR AXLE AND FRONT TRANSFER BOX, KNOCKS WHEN IN DRIVE.rita wrote:Hi accrag,
Cheers..
Re: transfer box
accrag wrote:HI YES PUT OIL IN REAR AXLE AND FRONT TRANSFER BOX, KNOCKS WHEN IN DRIVE.rita wrote:Hi accrag,
Cheers..
Hi does it knock when you freewheel?? and what do you mean FRONT transfer box.
PS have you checked the transmission mountings.Rubbers)
Cheers..
Re: transfer box
rita wrote:accrag wrote:HI YES PUT OIL IN REAR AXLE AND FRONT TRANSFER BOX, KNOCKS WHEN IN DRIVE.rita wrote:Hi accrag,
Cheers..
hi ite box that the two props are connected too. could be the diff box. no it doesnt knock in neutral. i hav'nt checked mountings will do. thaks.
Cheers..
