Car Thermometer question
- hembramacho
Going to have a go at fitting my new Digital LCD Car Thermometer tommorrow and was wondering if anyone has any thoughts on where to mount the external temperature sensor. I'm going to position the unit in the DIN space under the radio, so need a route to run the wire to outside somewhere and a good place to mount it so it doesn't get affected by engine heat, cold wind, etc. Having read up on here, a wheel arch or behind the front bumper seem good places. If so, what's the best way of routing the wire there, or any other suggestions??
Andrew
Andrew
				not so old
Re: Car Thermometer question
woul it not work putting it where the coolant alarm usually goes. that wouldnt be affected with heat ?
- mikexgough
routed mine through the big grommet Leisure battery side and down to the Bumper mounting bolt........ it's about 9 inches off the ground and gives me a 1c difference than my home all singing/dancing job....
- dandywarhol
I take it you're measuring outside temp. (kinda baffled by anna's suggestion
 ) They're usually located in the exterior mirror shell.
Had a Vauxhall Combo van for 13 years, year old when bought.. The external temp sensor was front centre behind the bumper, below the number plate... Stopped working 7 years in!!
Been thinking around this too for the last few days after an impulse buy
I was wondering about drilling a small hole in the air inlet for the engine, near the battery. Route for wire via driver side grommet.
Curently the probe is hanging out of the drivers door and not yet registered above 1 Centigrade!!
Live Bongo and prosper.
				not so old
dandywarhol wrote:I take it you're measuring outside temp. (kinda baffled by anna's suggestion) They're usually located in the exterior mirror shell.
- hembramacho
Cheers for that guys.
Andrew
						Seems like a good plan Mike - would have had a go today but the bongo's under 8 inches of snow.mikexgough wrote:routed mine through the big grommet Leisure battery side and down to the Bumper mounting bolt........ it's about 9 inches off the ground and gives me a 1c difference than my home all singing/dancing job....
Andrew
				Barrington
Hi Andrew mine is routed the same as Mikes and give a very accurate reading this way
									hembramacho wrote:Cheers for that guys.
Seems like a good plan Mike - would have had a go today but the bongo's under 8 inches of snow.mikexgough wrote:routed mine through the big grommet Leisure battery side and down to the Bumper mounting bolt........ it's about 9 inches off the ground and gives me a 1c difference than my home all singing/dancing job....![]()
Andrew
Music is my Sanctuary!
						- hembramacho
Cheers Barry. Might give it a go tomorrow if it's not too cold!Barrington wrote:Hi Andrew mine is routed the same as Mikes and give a very accurate reading this way
Andrew
Andrew
				David Edwards
I did the same as mike but fixed it behind my offside fog lamp blank plate, works a treat.
						- hembramacho
Finally sorted this today.
Put the sensor, as suggested, through the big grommet to under the bonnet and down to the bracket which holds my bull bars on. There was a handy hole underneath the headlight unit to thread it through too.
The unit looks like this
Cheers for all the help.
Andrew
Andrew
Thats neat!
I need a clock (and a voltmeter would be nice) anyway so am tempted to copy you.
looks like one of these
http://www.virtualvillage.co.uk/indoor- ... 0-066.html
I presume you cut off the cig lighter plug and wired it in directly.
Cheers.
Cheers.
- hembramacho
Thanks.bongod wrote:Thats neat!![]()
Cheers.
That's the right one - took a while to delivered, but at that price you can't complain.
I didn't cut the plug off, no. I've hard-wired 2x 12v sockets from the LB, via an in-line fuse, main switch in the dash, and then each socket has it's own seperate switch, which are the 2 shown in the photo, 1 each side of the unit. I mounted it all in a blank DIN plate from ebay. 1 switch is for the thermometer unit, and the other switch is for all my other 12v stuff via a 4 way splitter (ipod charger, DVD screens, Tomtom charger, etc,)
Andrew
I've seen one of these http://www.ikea.com/gb/en/catalog/products/20103016 fitted to a non bongo as a temp gauge on a newish astra owner said it worked fine and was fitted up on the thermostat housing area with some insulaion around it..
only £6.99 worth a punt??
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
