With that observation ..........I guess that's why there is some debate over hot or warm Bottom hose ...... for me I usually expect that under normal use....warm bottom hose and under more extreme conditions the bottom hose would be hot.... which is normal for all vehicles anywayhaydn callow wrote: At the last couple of meetings I have attended I checked the bottom hose of about a dozen Bongos as they arrived at reception (just stopped engine running) some had travelled 200 plus miles.....in all cases except 2 the bottom hose was cool.......after ticking over for a few mins the hose went hot.
In the other 2 cases they had ..a..been towing a heavy van...b..really "belting" along......this was in the summer.......During their journey I suspect the hose was getting hot on hills etc ....but when cruising along the engine did not require flow through the rad to keep temps down......
I also check every Bongo that visits my home.....same result
It's a shame that any decription over bottom hose temperature is used in the known coolant change processes Factory or otherwise, if we could get some kind of dialogue of what to "feel" for then disagreements etc about bottom hose temperature would be negated ..........
The Japanese only check the bottom hose once during a coolant change, by feel, just to check that coolant is hot inside the hose... as a further "mechanical"check to a known standard temp gauge position......after that they don't bother to check it again
