Ford Freeda steerng problems any ideas garage stumped
rita
Re: Ford Freeda steerng problems any ideas garage stumped
Post by rita » Wed Jan 12, 2011 1:49 pm
ultrasonic wrote:HI everyone
thanks for the tips, been back to the garage he says that I need a new UJ any ideas where I can get them from Ideally new but cheap LOL
Paul
Might be worth giving people like this a shout wit your details
http://www.nfauto.co.uk/steering_uj.htm
dandywarhol
Post by dandywarhol » Wed Jan 12, 2011 6:23 pm
Paul
Well, that was me shot down in flames then :wink:
ultrasonic
Post by ultrasonic » Wed Jan 12, 2011 6:28 pm
got one from bongobits.com lets hope this is the problem now all I have to get is 2 new headlamps as mine have gone yellow and a new window switch for the drivers side and it is back to new hopefully [-o<
=D>
THANKYOU EVERYONE FOR YOUR HELP MUCH APPRECIATED :D
dandywarhol
Post by dandywarhol » Wed Jan 12, 2011 7:23 pm
ultrasonic wrote:got one from bongobits.com lets hope this is the problem now all I have to get is 2 new headlamps as mine have gone yellow and a new window switch for the drivers side and it is back to new hopefully [-o<
=D>
Clean the headlamps with brasso or tee cut - job done! :D
Post by Northern Bongolow » Thu Jan 13, 2011 5:32 am
=D>
have you checked the drivers door wiring loom,they go duff as often as the switch,
ultrasonic
Post by ultrasonic » Wed Jan 26, 2011 12:39 pm
Thanks everyone was the UJ all fixed part from bongobits.com, alhtough not impressed with the £8.75 delivery charge and it taking over a week to get to me! but she is back on the road now thanks for your help everyone =D>
Post by Northern Bongolow » Fri Jan 28, 2011 5:21 am
Northern Bongolow wrote:long story but stick with it----------. last year my pinion seal was replaced(leaking slightly) fixed it with new seal until this november when i put my winter tyres on. changed from 195 70 15 tyre pressures were 40 psi to 205 65 15 36 psi. leaking again,put this down to strain on rack with the softer compound and lower pressures of the tyres , then the steering became lumpy to turn, and slow to centre after turning,used a product to attempt to fix called wynns powersteering leak fix (also for auto boxes),comes in a coke can sized tin. put it in at the weekend and wow what a difference. i have a smaller steering wheel than standard. now the steering feels very light in weight,it centres far better,and the lumpy feel at very low revs has gone.
dont really know what its done, i pressume its fixed an internal seal in the rack,or just cleaned out the power steering pump or rack.
end result the steering is like new for the price of a pack of fags.
dont know if its fixed the leak as its not stopped raining to check everything.
try it you never know.
well ---a couple of weeks later--------the rack is leaking worse than it ever was #-o .
changed the steering fluid back to straight psf, think cleaning the crud out of it was a bad idea as its now mot time :roll: .
new rack coming 8) .
anyone had a go at reconing their old ones,i have the kit,so anyone any tips.
lpgimports
Post by lpgimports » Fri Jan 28, 2011 10:05 am
Not a dig really but might be helpful to others if when changing topic completely that a new post is started, or it confused the hell out of people and you may not get the help needed as quick as possible.
This one has gone from non centering steering to headlamps to window switches to leaking steering racks...
Paul
gmaczbongo
Post by gmaczbongo » Fri Jan 28, 2011 3:13 pm
Let it flow.
It was all techie stuff.
