Replace glass rear parking mirror
SimonT
Post by SimonT » Sun Feb 22, 2009 7:13 pm
I have an intact parking mirror for my bongo, appart from the glass which is cracked. I also have another damaged parking mirror which is damaged appart from the glass. I wonder if anyone has any ideas how I migh put the glass into the intact moulding of the good one?
Hope this is clear :)
Simon from Exeter
Bongotastic !!
Re: Replace glass parking mirror
Post by bigdaddycain » Sun Feb 22, 2009 8:24 pm
I'm surprized that nobody on here that has replaced the mirror glass hasn't responded to this :? I've never done mine [-o< So i can only summise to a technique that can be employed.
I'd try removing the broken glass by prising it off using a flat headed screwdriver, (the glass is already broken, so nothing to lose there) When you have managed it, you can see how the lens is anchored (i'm guessing a ball & socket set up,probably plastic) Once you have determined how it is anchored, you can then hopefully remove the unbroken lens without damaging it.
haydn callow
Post by haydn callow » Sun Feb 22, 2009 9:23 pm
As you have a good glass in a damaged case..I would...cut the case away at the back...see what the score is and keep cutting the case till you have the mirror.
Then..
By now you should have some idea how it all goes together....Bash the broken glass out of your good case and refit the replacement..
http://www.coolantalarm.co.uk
Also BMW Clocks
Post by bigdaddycain » Sun Feb 22, 2009 9:59 pm
DOH #-o Sorry... rear parking mirror! #-o
Post by missfixit70 » Sun Feb 22, 2009 11:00 pm
Didn't you have to do yours Ste? or did you replace the whole mirror?
haydn callow
Post by haydn callow » Sun Feb 22, 2009 11:05 pm
This is a parking mirror....Door mirrors are easy but take time.
Also BMW Clocks
Post by bigdaddycain » Mon Feb 23, 2009 1:06 am
missfixit70 wrote:Didn't you have to do yours Ste? or did you replace the whole mirror?
Not yet kirsty, Haydn very kindly sent me out a broken armed rear mirror, with the glass still intact, i have yet to try to remove the glass though, i may have a complete spare mirror that has since cropped up, so the original mirror that haydn sent me may be able to be passed on to some body else (if that's ok with haydn of course) :wink:
Grahame at work
Post by Grahame at work » Mon Feb 23, 2009 1:35 pm
I've got a cracked mirror and have been waiting for someone to describe how to replace it.
So if all parties concerned are interested and willing to pass Haydn's ex on to me I would be up for the challenge of seeing if its possible. 8)
Regards Grahame
Re: Replace glass rear parking mirror
Post by Doone » Mon Feb 23, 2009 11:06 pm
You carefully break out the old mirror pieces. Then heat up the plastic surround until it expands, you'll find the new glass will drop into place. Don't turn it upside down while it's warm - leave it to cool and it will be a snug fit. Allan's fixed about 10 of these, he heats them up in front of a diesel heater.
Grahame at work
Post by Grahame at work » Mon Feb 23, 2009 11:14 pm
Thanks Doone - now all I have to do is locate a replacement mirror.
Regards Grahame
Post by bigdaddycain » Wed Feb 25, 2009 1:12 pm
Grahame at work wrote:Thanks Doone - now all I have to do is locate a replacement mirror.
Regards Grahame
PM sent :wink:
SimonT
Post by SimonT » Thu Jan 20, 2011 6:48 pm
For the record the heating method worked a treat.
I actually heated mine in the oven (wife out of the house). 200 degrees for not too long. The plastic expands quite rapidly. Fitted the glass and it was a complete success.
Simon from Exeter
Bongotastic !!
