Japanese alloy wheel valve size
gasace
Post by gasace » Wed Jan 26, 2011 8:48 pm
Hi everyone,
I have seen this topic on here before but I can not see if anyone has solved the problem, I can find 10mm valves on eBay and 10mm motorcycle valves as well, but I'm not sure if they will fit. If anyone has found the correct valve please let me know, i have to replace all the tyres soon.
Many Thanks
chipvan
Re: Japanese alloy wheel valve size
Post by chipvan » Wed Jan 26, 2011 9:08 pm
yes..a very trick one for us..
we had flush fit valves fitted as standard but couldnt add air to them..
My mate who works in tyrelad found some that fitted,they were a metal think 10mm size in chrome(oh well) some jap wheels have funny size valves! 10mm rings a bell..when you go and try to get 10mm they laugh at you..
Think it was a unerversal valve in the end that fitted.
BIt of a tip,try to make sure you have the right valves fitted b4 you want to go away for 2 weeks!
I took the bongo to a motorsport special tuning place (who claim they can fit anything) and after the mechanic took off old valve he didnt have a new one that fitted!!
He went bonkers at the manager.
I got mine sorted,but they were not happy,as they needed to take out bout 8 allen key screws to balence wheels...Took them 1.5 hours to fit 4 valves!
chipvan
Post by chipvan » Wed Jan 26, 2011 9:11 pm
DE-OGZ
Post by DE-OGZ » Wed Jan 26, 2011 9:34 pm
chipvan wrote:yes..a very trick one for us..
We use some of those little valve extender things from Halfrauds (or similar) that screw onto the valves then air line onto that.
Seems to work ok
chipvan
Post by chipvan » Wed Jan 26, 2011 11:45 pm
yep ,even they were different for us!..even deamon tweeks ones,gave up trying to get some that fitted as it was costing too much to try..
Must admit they did look nice!
Post by bigdaddycain » Thu Jan 27, 2011 2:25 pm
Drill bigger holes in the wheels to accept a standard size valve. :wink: No worries about finding replacements then should the valve become damaged at some stage. :wink:
chipvan
Post by chipvan » Thu Jan 27, 2011 8:34 pm
Now thats a good idea!!
gasace
Post by gasace » Fri Jan 28, 2011 8:16 am
Sounds good! what size drill?
bigdaddycain wrote:Drill bigger holes in the wheels to accept a standard size valve. :wink: No worries about finding replacements then should the valve become damaged at some stage. :wink:
gasace
Post by gasace » Sun Feb 06, 2011 3:29 pm
With the help of Freespirit (the dealer I bought the Bongo from) I have now found these valves on eBay http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
I will let you know if they fit
gasace
Post by gasace » Sat Mar 05, 2011 6:27 pm
Just has new tyres fitted, when the old tyres were taken off I found the valves I had bought on ebay were too small :( BUT the wheels would take a standard rubber valve :D :D :D . If anyone is not sure which valve will fit, I advise having the tyre removed to have a look before buying new valves. If anyone has Japanese wheels requiring a 6mm metal valve I now have 4 for sale :lol:
