antifreeze / coolant - which type?
DanO
Post by DanO » Tue Feb 15, 2011 8:03 pm
Hey
Need to refill the system but can't find anywhere that says what type to use......lots of helpful info on how to do it but nowhere can actually find out which type. Unless I wait to the weekend, I'm limited to going to Halfrauds, so as it's a P reg (97) 2.5TD do I buy the pre 1998 coolant?
Or is there somewhere online that delivers?
DanO
westonwarrior
Re: antifreeze / coolant - which type?
Post by westonwarrior » Tue Feb 15, 2011 8:26 pm
to top up you need to know what is in there already
that depends on when it was last changed and what type was used
If you are doing a complete drain flush and refill any should be ok
I think by reading the containers they say wether they are suitable for alloy heads (I may just be remembering that wrong)
DanO
Post by DanO » Tue Feb 15, 2011 8:31 pm
it's a refill from empty.
Dave.
Post by Dave. » Tue Feb 15, 2011 11:44 pm
I think commer RED is a good one to use but dont act on my 10p worth ive used it in mine.
Dave.
Post by Dave. » Tue Feb 15, 2011 11:45 pm
Just a quike note do you know how to bleed it properly cus you can crack the head easily if done wrong ?
