Help identify a few problems please.
james13009
Post by james13009 » Tue Feb 15, 2011 10:42 pm
I hoping a few you guys & girls can help me out Im idenifing a few problems with my bongo and want to fix them before they break...
The first off, identify a pipe I can seem to find anywhere on the parts manual:
The pipe is the thick black hose third in from the right. Attached to the corrodide hard pipe (brown in colour), the other end attaches to the rear heater matrix, I also wish to replace the smaller pipe to its right and the hard pipe.
So in the parts manual:
Would I be right in saying the larger pipe is 6130/6213A - confused as there is no picture for it. - **edit found the picture doesn't look right however**
The hard pipe it is attached to is 61-2D2 - Is this correct?? the parts manual shows the pipe end finishing horrizontal yet in my picture above where the the rubber hose connects clearly connects to a vertical pipe???
And the smaller pipe to the right that also connects to the heater matrixs god only know.
I'm starting to think Im looking a the wrong drawing
Part two..
Is the pipe to the turbo charger -
Part number 13-539A - Just to confirm its a water pipe too and not an oil pipe
Seems a very short line to replace any one have a cheaper alturnative replacement places I could go to for this? Anyone know the ID and wall thickness off chance. (Im not too lazy to measure just that the bongo is 40mins drive away in a lockup and I forgot to check tonight.)
Part three
My long block seem very oiyl, has my headgasket gone? There are no other signs of it yet, no mayo under the cap no over-heating. Didn't notice it at first as I just though the block was black although the head is a shiny silver. Some pictures
Only seems oily front the front of the engine and the drivers side
Couple of videos
Front:
TBA
Drivers Side
TBA
Last question (Sorry!)
What are these to boxes by the battery for:
Dave.
Re: Help identify a few problems please.
Post by Dave. » Tue Feb 15, 2011 11:30 pm
AS far as im aware the oily front drivers side is caused by the egr valve system on the inlet manifold very common
The pipes you mention ,what is the problem with them? they look like they are covered in underbody waxoil or stone chip stuff
The bongo MUST be bled correctly and not many garages know how to do it properly they arnt the same as the everyday car to do
no idea what the boxes are by the battery :)
Post by Northern Bongolow » Wed Feb 16, 2011 5:58 am
picture 2 is indeed a coolant/water pipe.
visit you local mazda dealer they can order the steel /rubber pipes you require as they have a bongo database.
or contact one of the parts/service suppliers who advertise on here.
allans of plymouth has just replaced ALL the coolant pipes on a bongo,so he should have the info you require.
james13009
Post by james13009 » Wed Feb 16, 2011 2:17 pm
The two videos of the oil:
Side
Front:
james13009
Post by james13009 » Wed Feb 16, 2011 2:22 pm
The three pipes I've mensions (Large / Small Rubber Pipes + Hardpipe) One is leaking a green fluid - must be anti-freeze. I'm taking this bongo on a trip all around europe so need to get these sorted out.
Post by Northern Bongolow » Wed Feb 16, 2011 2:32 pm
the 2 thick pipes supply/return from rear heater (antifreeze/coolant). the 2 thin pipes are for the rear aircon,it will be the oil thats leaking(various colours can be used).
if your doing europe you may need this fixing.
helen&tony
Post by helen&tony » Wed Feb 16, 2011 4:09 pm
Hi James
Are you a cameraman on HORROR films???... :shock: :shock: :shock: :shock: :shock: judging from those videos :lol: :lol: :lol: :lol: :lol: ..Not much of a worry, if you aren't losing oil...it's almost certainly baked-on crud that's leaked from the EGR system....Mine's pretty gunky.....I have left it , I'm afraid....it adds a touch of "Dirty Diesel Authenticity"....just check that your oil level is stable...my oil stays fairly good between services, and last year I checked oil consumption at 3,600 miles per pint, and my engine is crabby on that side!
james13009
Post by james13009 » Thu Feb 17, 2011 2:13 pm
james13009 wrote:The three pipes I've mensions (Large / Small Rubber Pipes + Hardpipe) One is leaking a green fluid - must be anti-freeze. I'm taking this bongo on a trip all around europe so need to get these sorted out.
Ahhh *Spams my head* no wonder I can't find it in the heating or cooling section. One problem down. :D
james13009
Post by james13009 » Thu Feb 17, 2011 2:17 pm
helen&tony wrote:Hi James
Hehe there is abit of a 'Blaire Witch' feel too the Video, thanks for the advice. I'm going to give it a quick steam clean and keep an eye on it for now.
