Can anyone identify this please.
PixieAndTheMoon
Post by PixieAndTheMoon » Thu Mar 17, 2011 3:53 pm
Hello, we were going to fit an eberspacher under the passenger seat as some others have done. However we have the below under there also that others don't appear to have. Any clues gratefully appreciated.
Jo
Re: Can anyone identify this please.
Post by Northern Bongolow » Thu Mar 17, 2011 3:58 pm
its the winterpack conrol valves.you will have a switch near your right knee with an engine symbol on it.
its still possible to fit it here,as some just remove the whole unit.
there are other places to fit your eber, is yours 2wd or 4 wdrive.
PixieAndTheMoon
Post by PixieAndTheMoon » Thu Mar 17, 2011 4:09 pm
Thanks Ady, it is a 4WD, we are just toying around with the idea of putting in the tool box area
Jo
Post by Northern Bongolow » Fri Mar 18, 2011 4:53 am
if it was just a 2wd you could mount the heater where the front dif/axle should be,if you see what i mean :lol:
mikexgough
Post by mikexgough » Fri Mar 18, 2011 6:05 am
PixieAndTheMoon wrote:Thanks Ady, it is a 4WD, we are just toying around with the idea of putting in the tool box area
Jo
the Japs are known to put theirs by the tool box area... here and follow the link for the install
Tomo 53
Post by Tomo 53 » Fri Mar 18, 2011 9:33 am
Jo
its only a 5 minute job to remove the winter pack .leave the valve on the exhaust. just remove the pipe and the vacuum unit .dont forget to plug the small rubber hose.
Tomo
Post by mikeonb4c » Fri Mar 18, 2011 4:26 pm
Noisy little buggers though these diesel heaters aren't they? I wonder if a space could be found at the front under the bonnet so as far away as poss. from sleeping occupants. Still must annoy the neighbours though eh?
Grabs coat and flies off before he gets shot down :lol: :lol: :lol:
Post by Bob » Fri Mar 18, 2011 4:41 pm
Agree there Mike, we had one camped next to us last year and it ain't so bad when its running but the ******* thing switches on and off all night.
Personaly I'd use it to warm the van before bed and then rely on good sleeping bags, maybe setting the timer for the morning.
PixieAndTheMoon
Post by PixieAndTheMoon » Fri Mar 18, 2011 9:11 pm
Very helpful Ady if we had a 2WD lol
Thanks for the link Mike, but we are going to try and put the main unit in the toolbox. It shouldn't pick up so much muck then, keep the unit clean.
They are noisy beggers yes, that is my concern and I am insisting it has a silencer, someone didn't have one did they! But if you camp up in a field or anywhere you can isolate yourself a bit as you are self contained if you know what I mean.
That is my intention Bob like with central heating it should kick in just before we wake up. When we are in holiday mode it is not too early. lol
Keefy :D
Jo
Post by Northern Bongolow » Sat Mar 19, 2011 4:11 am
fit the 7 day timer on it and you get a warm motor evey morning,and no scrapping in the winter. :D :D .(so im told).
Dave.
Post by Dave. » Sat Mar 19, 2011 11:55 am
just dont buy the older d2 airtronic :roll: they like to eat ecu's ££££
