Will the area around the striker plate have to be cut away and fresh steel welded back in?
Back vallence rotted out
Re: Back vallence rotted out
Sorry to see how bad the valance has got on your bongo Sparkymik.
  Hopefully it's not daft £££'s to get it sorted
 I don't envy whoever has to line that plate back up again...
Dabs wrote:And a sharp intake of breath when revealed!!bigdaddycain wrote: takes less than a minute to check
Oh yes! Both me AND dabs held our breath when i pulled that strip off!
Good man! I know your bongo hibernates during the winter too Graham, so you may be ok.dobby wrote:Bongo's back from Mr T's at the weekend, next job on the list.
New water pump and a coolant flush hopefully plus an MOT
I've got everything crossed for you bud!
Well I can say for sure the rot comes from inside the box beam/section that the floor pan sits on, if you are under the back vallence and look up and to the rear you will be under the botton profile of the box section, here's the rub,there is a massive hole in it and the weather and road spray get up and into it, in fact there are a few holes but this one is directly under the door latch, the access hole for the spare wheal tool passess right through the section how ya gonna stop it from rotting out? it fills with road spray, all the time your on a wet road, Oh well more tomorrow, If I had'nt become unemloyed I would not have all this time on my hands and I would still be blissfully ignorant
Sparky
									Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
This is another place that most people miss when they underseal, thin down a 1 litre can andusing a probe, blast it in the 8 holes that can be accessed along the rear crossmember, bo the same for sides and front, no guarantee it will stop it completelt but it does the job slowing it down!
Julian
						Julian
Had a look at the valance on mine yesterday, looks like I caught it just in time so a big Thank you to Dave and SparkyMik for flagging this issue up and also to Julian for the tip on spraying it.
