central locking/radio
greynomad2010
Post by greynomad2010 » Tue Mar 29, 2011 10:37 pm
hi, 1st posting, problem i'av had, central locking, radio, internal lights have stopped working at same time, also the door open warning light stay's on with all doors shut :( , has anyone got any idea's of the problem please, thanks
Re: central locking/radio
Post by bigdaddycain » Tue Mar 29, 2011 10:41 pm
I'm not sure about the door open warning light...for the other issues, is your leisure battery flat? (if fitted) And welcome! :D
Post by g8dhe » Wed Mar 30, 2011 9:19 am
Well those three functions are all controlled by this single common fuse (as well as others);
tallbongo
Post by tallbongo » Wed Mar 30, 2011 7:02 pm
As per the previous two responses for the first three of your problems. Check your door switches are working for the other.
Driver's side one shown here.
95 N Reg 4WD Manual AFT Bongo
Image Image
Mattylad
Post by Mattylad » Wed Mar 30, 2011 7:15 pm
I also had an issue with central locking and dirvers side speaker not working. It turned out to be the the wiring loom that runs from your door into the 'A' post had weakened with the door opening and sutting and opening and shutting (you get the picture). This caused the wires to perish internally.
Only took half a day to replace the damaged wires and all was good (most of that time was spent figuring how you remove the internal door release lever to remove the door trim). I also used thicker wire and small bore flexible conduit to prevent it happening again.
Good Luck.
Matty
greynomad2010
Post by greynomad2010 » Thu Mar 31, 2011 9:26 pm
hi ya, checked the fuse & found it blown, new fuse fitted and all working well, thanks for th help Dean :D
