BONGO NOT STARTING
ka100uk
BONGO NOT STARTING
Post by ka100uk » Sat May 07, 2011 12:07 am
Sorry new to this. Could anyone help, i am having trouble starting my bongo. It has been running fine up until this morning
and now it wont start. It seem`s like there is no fuel ? Thank you
jutwit
Re: BONGO NOT STARTING
Post by jutwit » Sat May 07, 2011 12:13 am
is there fuel in it? gauge could be lying
The Great Pretender
Post by The Great Pretender » Sat May 07, 2011 12:58 am
No fuel sounds like a problem with the stop valve on the injector pump. :wink:
And welcome to the forum.
To infinity and beyond
lazyb5
Post by lazyb5 » Sat May 07, 2011 1:01 am
Hi & welcome , if you mean its turning over but not starting it could be fuel starvation but could be other things also. Can you give us more description.
westonwarrior
Post by westonwarrior » Sat May 07, 2011 7:57 am
Is it a deisle? if so it could be the glow plugs or fuseable link or relay
check that you are getting the volts accross the glowplug rail
ka100uk
Post by ka100uk » Sat May 07, 2011 9:19 am
Thank you. There is fuel in the vehicle but no exhaust fumes when i turn it over, i presume indicating that that there is no fuel in the pump/engine. The glow plugs have power. Thanks
jaylee
Post by jaylee » Sat May 07, 2011 9:24 am
A quick one to look at.. could be wrong/ do no harm..?? Check the 15amp fuse, 1st on the left, 2nd row down, cab fuse box..??
ka100uk
Post by ka100uk » Sat May 07, 2011 8:25 pm
Thank you all for your help. It turned out to be the fuel stop valve so thank`s Great Pretender and all those who thought the same. :D
