Waxoyling inner wheel arches
binky
Post by binky » Mon May 16, 2011 4:22 pm
The bus is nearly ready for the road, the Waxoyl bought. I can get at the inner sills from underneath, but I have a side kitchen conversion. Can I get at the inner arches without pulling the kitchen out? It's a 1998 'Facelift' V6.
haydn callow
Re: Waxoyling inner wheel arches
Post by haydn callow » Mon May 16, 2011 4:42 pm
Yes,, via the rear light clusters.
http://www.coolantalarm.co.uk
Also BMW Clocks
binky
Post by binky » Mon May 16, 2011 4:49 pm
Ah excellent, thank you.
haydn callow
Post by haydn callow » Mon May 16, 2011 5:21 pm
To remove the clusters....remove 2 x crosshead screws and "push" the cluster sidways. Do NOT try and pull it backwards
Also BMW Clocks
Diplomat
Post by Diplomat » Mon May 16, 2011 7:21 pm
Don't forget to pull the seat belts fully out and tie them up so that only the part that is left behind gets oily, not the part that goes over your rear passengers' clothes ( not a bad idea even if the back is already converted, someone might want to convert it back some day).
Frank
They flew, I took up naturism
binky
Post by binky » Mon May 16, 2011 7:49 pm
Great tips, everyone, thank you.
