I remember you saying that you had some
I fancy fitting these. But 2hrs? Is it really that quick and easy, even for an ageing numpty like me?dandemann8 wrote:Hi Helen scroll down this link you will see two, one for standard and one for lowered.helen&tony wrote:Hi dandemann
What system did you use?...
http://www.mattsavage.com/acatalog/copy ... rings.html
Real easy to fit, about two hours roughly![]()
Hope this helps
missfixit70 wrote:Depends how you do it, I dropped my suspension & gave it all a good clean & wax oil on the bits that are usually out of sight while I was at it, probably wasn't any more than 3 hours or so with teabreaks & fannying about with different options for runnning the air hose. I think BongoTerry here - http://www.igmaynard.co.uk/bongo/forum/ ... 72#p444472 didn't take long from what he said when I was chatting at Softies & his right arm is pretty much fubar after a bike smash. As he says in his post, if he can do it, anyone canChallenge laid down Mike, I'll expect it to be done & ready for inspection at Stourport
TerryG wrote:But the handbook states front 2wd: 1.8 bar (24psi); front 4wd: 2.0 bar (29psi); and rear (both) 2.4 bar (35psi).
So what is one to do?
teenmal wrote:TerryG wrote:But the handbook states front 2wd: 1.8 bar (24psi); front 4wd: 2.0 bar (29psi); and rear (both) 2.4 bar (35psi).
TerryG wrote:teenmal wrote:TerryG wrote:But the handbook states front 2wd: 1.8 bar (24psi); front 4wd: 2.0 bar (29psi); and rear (both) 2.4 bar (35psi).
Simple,one could sling the handbook or do what it says,I think the vehicle manufacturers should know what the tyre pressure should be.They spend millions on development.
Yes indeed, that's what I thought and that's what I've been doing, then I read all these posts about running pressures in the high 30's and into the 40's and thought maybe there was some other authority that I wasn't aware of. I tried running higher pressures and it was like sitting on a roller-skate - and here in Kent where there appears to be more pothole than road these days, a bit of sidewall compliance is very welcome I can tell you!
missfixit70 wrote:Before I'd ever heard of Bongofury or indeed bongos, a friend got a bongo, we set the tyre pressures to those on the door plate (which meant letting a LOT of air out from where they were set at the time), tyres were practically flat, handled like sh*t. When I got my bongo, trial & error & discussions on here led me to the 38/40 that I now use on my 17's.
Apparantly (have no idea how true this is) the original Jap tyres were softer compound or sumat, top speeds over there are generally lower, not sure if that has a bearing on it. There have been endless tyre debates over the years that have caused almost as much dummy spitting as coolant issues![]()
It's up to you basically, follow whichever train of thought makes most sense to you.
