I have found a 2 small patches of rust on my roof, what products would you use to treat this b4 priming and spraying ??
Rust spot
Bogmonster40
Rust spot
Not sure if i have brought this up previous, i have looked through my posts but not found it ???
V6 2.5i Tintop Aero Petrol/LPG
dandemann8
Re: Rust spot
I'm guessing its a Tintop not a AFT
I always used to use Rusteater many years ago which I found did the job
Bongo no more........... ;-(
Re: Rust spot
For little spots I've just been cleaning them witha glass fire etching pencil, touching on Kurust with an artists paintbrush, then ditto for the primer, metallic paint and (most importantly) lacquer (which is in a spray can so a pray a bit into the cap and use by brush from there.
I reaosned that for small repairs, both brushing and spraying would show as a patch (sparaying probably worse), and as these were v. small patches and I'm more concerned about protection that appearance, touch-up brushing would be more effective and simpler. In the event, the touch-ups hardly show (certainly no more than the scratches that brittle old lacquer is prone to from bushes etc.).
There is apparently some really good stuff, and it has been mentioned on here (I think its a kind of epoxy) in connection with painting and protecting cleaned of rust, but I can't remember its name - it might be worth having a search to see what you can find.
Re: Rust spot
I don't know if Jenolite is still available? I found that a really good product some years ago whilst patching a car up.
Bogmonster40
Re: Rust spot
thanks people, that gives me something to go on over the holiday whilst the family are on the beach !!
Re: Rust spot
OR... YOU do the beach thing and let the family get their hands mucky! You can offset the favour by driving them to the beach, and let them watch you build sandcastles whilst the missus and kids get busy on the rust spot
