They have plenty of head problems to, they also fit the stat in the bottom hose.
Mazda chose to try a different route.
Did they succeed?
I think they hoped the bleed pipe would contain excess air, may be the reason for its length?
IMHO no, why, because the engine position from an engineer's perspective is a ba**s up.
As a package it is a brilliant use of space.
Fig. 2 In the patent shows a vapour pipe rising to the degassing tank, if in reality you could do that you would have a natural upward path from the engine to the radiator for the main coolant pipe allowing a natural convection path as per the 'old days' negating the need for the patent.
