headlight meltdown
francisarcher
headlight meltdown
Both front headlight connectors (the plastic bits that connects directly to the bulb) melted a few weeks ago. Have now changed them however they still get extremely hot and so I dare not use them.
I have had AVA liesure try and find the problem - however they can't crack it and are suggesting that perhaps the whole front loom may need changing (at over ?1000) - HELP -
I feel there must be a simpler answer as all electrics are working fine including all the mods of the headlights - but they are just overheating when on.
Any ideas
Any ideas
white van man
francisarcher
white van man
nick & jem
Vanmanerik
Hot Lights
Check the earth wires, if it is corroded cleanit up.
Bad earths = high resistance = heat!
owelly
My local factors sell the headlamp 3 hole connectors or try AES ( http://www.autoelectricsupplies.co.uk/ ).
The trouble with mine was dirty terminals and daft 100w bulbs. I've rewired the headlights through relays (from EAS!) and put a blob of vaseline on the terminals to keep them clean. They do get a bit warm but they will do, they're on the back of a blummin hot bulb!!
