Lurking behind fuel pump.?
helen&tony
Re: Lurking behind fuel pump.?
Post by helen&tony » Fri Jun 24, 2011 9:37 am
Or a Terribly Perceptive Student of Crass Reality??? :lol: :lol: :lol: :lol:
jaylee
Post by jaylee » Fri Jun 24, 2011 10:07 am
corblimey wrote:Unfortunately it's not a flux capacitor..... it's a T.P.S.C.R or Throttle Position Sensor Compensation Resistor for short.
Ah ha! You are an absolute star!! 8) :!: :!: It did look like it could have been some sort of bypass fuse? But it all makes sense now...
I can head off to the bash & sleep nights... Though with all this messin' i haven't had time to wash the van! :oops:
Cheers!
Just one thing.. What would the symptom be if it broke?? (My van works fine!) :D
corblimey
Post by corblimey » Fri Jun 24, 2011 10:24 am
I'm guessing here because I don't know but I reckon you'd see the gearbox shifts happen either earlier or later.
Diplomat
Post by Diplomat » Fri Jun 24, 2011 8:58 pm
So, the next question is "Do they come in different values?"
If so, it's got to be a better way of altering the gear change point than by fiddling around with the TPS itself and not being able to recover the original setting if you get it wrong.
When I get time I will have a look and see if mine is also a 948 no 4.
Maybe it would work better with a 948 no 3 or perhaps a 947 no 4.
Frank
They flew, I took up naturism
Post by g8dhe » Fri Jun 24, 2011 9:22 pm
The only part I reckon it could be is the "Dropper Resistor" this appears to feed a reduced voltage to the ATF solenoids etc its on the connector B2-20 below, can you confirm the wire colours as being a Red with White stripe and a Blue with Orange stripe ?;
The connector for it is shown as being here, on the passenger side ?
are you at the Bash Jaylee ?
The above item seems to be here on the Lush Diagrams 18-831 http://lushprojects.com/bongopartsmk2/c ... o=.html#13
Not sure that this is the same component to be honest but there is nothing in the wiring diagrams about a TPSCR either !
jaylee
Post by jaylee » Thu Jun 30, 2011 6:12 pm
g8dhe wrote:The only part I reckon it could be is the "Dropper Resistor" this appears to feed a reduced voltage to the ATF solenoids etc its on the connector B2-20 below, can you confirm the wire colours as being a Red with White stripe and a Blue with Orange stripe ?;
Just had the seat up Geoff... One wire is orange, the other one blue.. No other colours on there that i can see.. :-k
corblimey
Post by corblimey » Thu Jun 30, 2011 6:37 pm
Pretty sure it's your TPSCR. Finally got round to digging out my workshop manual last night and if it's connected to your FIP loom connector on pins D & E then I'm certain.
FIP = fuel injection pump. That's the manual's TLA (three letter abreviation) not mine :D
Poohbear
Post by Poohbear » Thu Jun 30, 2011 7:19 pm
corblimey wrote:FIP = fuel injection pump. That's the manual's TLA (three letter abreviation) not mine :D
You mean Three Letter Acronym (not abbreviation) :wink:
corblimey
Post by corblimey » Thu Jun 30, 2011 7:43 pm
Of course!
What I think and what I type are often not the same :lol:
Post by g8dhe » Thu Jun 30, 2011 8:34 pm
Interesting that they don't show the fuel pump of the diesel on the wiring diagram, unless I'm going blind with all this travel!
What pins on the ECU does this FIP loom connect to does it say in the workshop manual?
Jaylee, OK not too surprising with the wire colours, as it didn't seem to be located in the right place.
jaylee
Post by jaylee » Thu Jun 30, 2011 9:15 pm
Just found the bit on Lush...
Top left corner with the star above it, is the bit that runs off the loom, connects to part 13-1552 http://lushprojects.com/bongopartsmk2/c ... o=.html#33
corblimey
Post by corblimey » Fri Jul 01, 2011 1:43 pm
Not sure Geoff, I'll take a look when I have the a minute.
