Gear box problem advise required
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Post by M 80NGO » Fri Jun 24, 2011 8:41 pm
Hi my bongo has been off the road for just over a week now having the fuel pump inner seals replaced, now its all back together i seem to have aquired a slight gear box issue, it was fine before it was parked up and all gears engage forward and reverse but now if i pull away in drive it won't change gear it just revs higher and higher until 4000 rpm at which point it will change up, if i push the hold button so the hold light on the dash comes on then it changes gear fine and drives as it should then after a while the hold light starts flashing, i can only assume its summat simple as it was working fine before and the gearbox oil levels are ok tho i did give it half a litre to bring it back to the max mark, oil level was checked with the engine running and in Neutral.
Any info will be greatly recieved, Pete.
lazyb5
Re: Gear box problem advise required
Post by lazyb5 » Fri Jun 24, 2011 8:47 pm
Hi, if they were working on the fuel pump check your throttle position sensor it affects when the box changes up. That sabout all i can think of they may have even forgot to connect it although i would have thought the hold light would flash from the start. I`ll see if i can find the thread about the TPS for you.
M 80NGO
Post by M 80NGO » Fri Jun 24, 2011 9:03 pm
lazyb5 wrote:Hi, if they were working on the fuel pump check your throttle position sensor it affects when the box changes up. That sabout all i can think of they may have even forgot to connect it although i would have thought the hold light would flash from the start. I`ll see if i can find the thread about the TPS for you.
Thanx for the input where is the throttle position sensor located ?
Diplomat
Post by Diplomat » Fri Jun 24, 2011 9:07 pm
Maybe the T.P.S.C.R. has come adrift.
http://www.igmaynard.co.uk/bongo/forum/ ... 54&start=0
4000 rpm on a Bongo sounds horrendous.
Frank
They flew, I took up naturism
lazyb5
Post by lazyb5 » Fri Jun 24, 2011 9:08 pm
http://www.igmaynard.co.uk/bongo/forum/ ... nt#p161814
Hope that helps cant think it can be anything else
Ooh that doesnt show where it is its right on top of the diesel pump. http://lushprojects.com/bongopartsmk2/c ... mgno=.html
its the thing at the top with a star on it.
M 80NGO
Post by M 80NGO » Fri Jun 24, 2011 10:35 pm
lazyb5 wrote:http://www.igmaynard.co.uk/bongo/forum/ ... nt#p161814
You sir are a genius =D> i just been outside messing about with the throttle position sensor then test driving and its all working ok it does need fine tuning when the rain stops but i'll get it back into the garage next week and get there auto electrician to set it correctly.
Thanx so so much cos now cinderella ( thats me ) can go to the ball ( thats the bongo bash ) =D> =D> =D> :wink:
lazyb5
Post by lazyb5 » Sat Jun 25, 2011 12:20 am
Excellent see you there tomorrow i`ll be there about 12 ish :D
