Now with my new car I have fitted a LB and new radio but I didn't want to have to turn it on and off every time I go out, which I would if I just wired it to the LB but wanted to be able to use it without the keys in from the LB while out or camping etc. also had in the back of my mind the last one draining the LB.
So I could have had a on off on switch and feed one side from the starter and one from the Leisure batteries but didn't want the off.
My solution was to get a cross over relay and on off switch so with the switch off it works from the ignition switch and flick the switch and the relay changes the power source to the leisure battery
I used a on off led switch and a relay like THIS
I already had a willinton wire going into the bottom of fuse 8 so disconnected the acc input on the radio in the loom, this ment lights cig socket etc still work from lb.
On the relay
I wired terminal 86 to the lB via a spare wire in the willinton kit through the switch and 85 to earth
30 went to the acc input on the radio
87a came from the top of fuse 8 through an in line fuse so powered by ignition
and 87 via the other wire from the willinton kit
So now with the switch off it works on ignition and with the switch on works from the lb and works without the keys in.
Switch, relay, connectors, fuse holder and Wire cost around £20, I bought from a local motor supplies so paid more than online. and got all rated at over 10 amp as that's the fuse in the radio (wire is 17amp relay and switch much more)
Tested it at the bash and works a treat.
Edit a wiring diagram curtisy of widdowson2008 showing with the switch off, running from the ignition switch and second with the switch, on permanent feed from the LB
Thanks Steve
Rob
