Will long rails fit?
Hi I know this has been asked before but to be clear will long rails bolt straight into a van with short rails? Also am i right thinking with long rails fitted and middle seat rotated the seat will move and make up the bed as normal?
- daveblueozzie
Re: Will long rails fit?
You will have to drill out the holes for the bolts , Ive been informed that the captive nuts are under the floor, so be careful drilling out.
Lost without my Bongo.
- missfixit70
Yes & yes
This recent thread should point you in the right direction - http://www.igmaynard.co.uk/bongo/forum/ ... =long+rail
- daveblueozzie
I knew I had read it some where.missfixit70 wrote:Yes & yes![]()
buntytw26
Hello, in case you dont read it again, my long rails are in and the mid bench which is reversed folds flat and along with the front seat and drivers seat flat, I now have a big bed, albeit a bit lumpy. I have 2 thermarests anyway so that plus a 2" memory foam kingsize mattress topper we will be fine and dandy! If you want pics just ask.
