After swapping PM's with Dave-Aber I did some investigations. All Willington fuses appeared to be intact and on unscrewing the PMS3V unit (serial number 58982) I found that everything was wired up but could not find any relays. Similarly I could not find any at the Leisure Battery end either, just after passing through the bulkhead the cable splits into 5 with one not being carried on and the others protected by 3@15a fuses and 1@10a fuse (all ok). The PMS3V is wired up as DC+ve (pumps, lights, Aux1 and Aux2), Fused 15a (fridge in and fridge out) and DC-ve (Car+ and Van+). No idea idf this is right as I am no electriciain.I had a bit of a problem with my leisure battery on my holiday in the IOM last week. My Bongo has long been fitted with a willinton kit. But recently while the leisure battery has been charging up fine from the alternator via the starter battery when on the move, nothing seems to be getting to the leisure battery via the PMS unit while the Bongo is on a hookup, looking at the voltmeter which DBO fitted for me you can see the voltage dropping slowly.
I have checked all the fuses on the PMS unit and those of the Bongo in the cab and engine bay, not to mention those on the willington kit but all seem to be ok. Seems to me that it must be a duff relay somewhere but I am dammed if I can find it.
Before I left for my holiday I got the local auto electrician to test both my batteries, he said that the leisure battery was fine but the starter battery was on the way out so I got a new one. Could the power that taken by the fridge (if directly connected to the leisure battery), the clock, blinds and radio etc be more than the PMS is producing or is it just that the impossible to find relay has gone kaput.
Tony
Putting everything back again I checked that the fridge was off/lowest setting on the dial inside it. Hooked up the Bongo to the house supply, switched on (up) the far left and far right MCB's, switched on the supply then chose van to charge up the leisure battery. ( only the clock and the radio should be drawing power from the leisure battery now). The reading on the Leisure battery (via DBO's voltmeter) was now 11.18v at 23.00 hrs on Saturday night. Checked the reading again at 9.30hrs this morning, the reading had gone down to 8.60v rather than up???. Immediately disconnected everything and put the Elecsol Leisure battery on charge with the CETK trickle charger to try to save it.
CAN ANYONE TELL ME WHAT IS GOING ON.
Tony
