Bonjour! In switzerland. Two problems.
1. temperature gauge not moving.
2. fan kicks in immediately
no coolant level problems...level has remained static.
mechanical brother on hand if anyone can advise on what / where to check.
Have disconnected fan (removed fuse) to check - engine comes up to temp, but no movement on temp gauge.
non working temp guage but fan kicks in immediately
Re: non working temp guage but fan kicks in immediately
appears to be fixed now.... temp / fan sensor under seat not properly attached; hopefully problem solved. Air con also now pumping warm air - handy, as it's not that warm here in switzerland at the moment!
