metal pipe
arranlass
metal pipe
Post by arranlass » Sun Jul 24, 2011 9:03 pm
can anyone help?
the metal oil pipes which goes to the gear box has started to leak and weap fluid underneath the drivers side. our local garage has said not to drive it. and if we get the pipe he will fit it but i cant see anywhere to buy the pipes? does anyone know where i can? [-o<
Re: metal pipe
Post by missfixit70 » Sun Jul 24, 2011 9:13 pm
Assuming yours is a diesel automatic, here's the schematic - http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Just about any parts can be obtained through a half decent Mazda dealer or any of the Bongo specialist garages, ie Allans, Bellhill, AVA, etc, you'll need the vin number to verify the right parts & it may take a month or two.
You could get one from a scrapper, not a high demand part, so there should be a few around, you'll need to specify age, engine type, gearbox type.
Alternatively, it is just a metal pipe, which should either be repairable, or someone should be able to make one up, replace with a length of oil resistant hose of the right size.
arranlass
Re: metal pipe
Post by arranlass » Sun Jul 24, 2011 9:21 pm
thanks, will phone around and see. :)
