heat inside cabin
jpdridley
heat inside cabin
Had two heating issues during otherwise great 3k mile trip this august. Firstly the air con only seems to work in the front....any ideas? Secondly there is a huge heat issue behind the drivers seat. I thought it was the fridge but it was there even when off. Seems to be heating up behind panel near drivers seat belt? Should I be concerned?
- missfixit70
Re: heat inside cabin
Aircon has to be turned on in the rear, it's a seperate switch in the dash with "Rear" on it I think & the Rear button if it's digital climate control, then the temp has to be set in the rear manually for either system. Could be the heater flaps are fubar if all that's been done (which could maybe explain the heat behind the drivers seat), this faq may help - http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
If it's not the rear heaters causing the heat behind the drivers seat, check the seals on the engine covers under the seats.
