Handbrake Wiring
bikerbob
Handbrake Wiring
Post by bikerbob » Sat Aug 20, 2011 10:06 am
Have just accessed passenger side engine department and noticed that the purple wire is severed near to the handbrake activating switch.The green wire is ok & the warning light on the dash works ie handbrake on warning light on - handbrake off warning light off. Any ideas as to why & should I recconect the purple wire, if so whats it purpose.
teenmal
Re: Handbrake Wiring
Post by teenmal » Sat Aug 20, 2011 10:25 am
bikerbob wrote:Have just accessed passenger side engine department and noticed that the purple wire is severed near to the handbrake activating switch.The green wire is ok & the warning light on the dash works ie handbrake on warning light on - handbrake off warning light off. Any ideas as to why & should I recconect the purple wire, if so whats it purpose.
Hi,does it,did it have a turbo timer fitted.
bikerbob
Post by bikerbob » Sat Aug 20, 2011 10:38 am
Yes, the timer is a Blitz but no instructions as to how to fly it so its always switched off.
teenmal
Post by teenmal » Sat Aug 20, 2011 10:47 am
bikerbob wrote:Yes, the timer is a Blitz but no instructions as to how to fly it so its always switched off.
Hi the Blitz has a purple hand brake wire((cut out switch)) Page 3
http://www.naikontuning.com/det_tec/wp- ... -blitz.pdf
Cheers..
bikerbob
Post by bikerbob » Sat Aug 20, 2011 11:07 am
THANKS FOR THE INFO,althugh operating instructions are not for my Blitz model will see if they are compatable.
teenmal
Post by teenmal » Sat Aug 20, 2011 11:13 am
bikerbob wrote:THANKS FOR THE INFO,althugh operating instructions are not for my Blitz model will see if they are compatable.
Hi I didnt know your model,it was just to show you the purple wire.Hope it helps.
PS what model do you have....
bikerbob
Post by bikerbob » Sat Aug 20, 2011 11:54 am
Yes it explained every thing thanks, very much appreciated, Blitz model MSTT there is a number 10-906 a serial number?
Regards Bob
