Banjo.
jaylee
Banjo.
Post by jaylee » Mon Aug 22, 2011 6:31 pm
I fancy playing mechanic on my day off tomorrow!
OK, done the research.... (Members aria & stuff on this forum.) Got the tools needed.. (cotton buds from old tape cleaning days, even got a couple of those magnets on extendible rods lying about!)
What i don't know is.... What do you clean the filter out with? (Should any crud be built up on the gaus strainer when i remove it..)
I figured i don't want to be using anything with a higher combustion rate than diesel.... [-X
wonkanoby
Re: Banjo.
Post by wonkanoby » Mon Aug 22, 2011 7:01 pm
well i would just was in petrol and let it dry
chipvan
Re: Banjo.
Post by chipvan » Mon Aug 22, 2011 7:06 pm
cilit bang..way to go,let it soak in for 20 mins
nicstrike
Re: Banjo.
Post by nicstrike » Mon Aug 22, 2011 7:31 pm
ours wasn't too bad , just gave it a blast off with some carb cleaner.
Re: Banjo.
Post by francophile1947 » Mon Aug 22, 2011 7:34 pm
It fits in the nozzle of a tyre inflater - that's how I did mine 8)
helen&tony
Re: Banjo.
Post by helen&tony » Mon Aug 22, 2011 7:40 pm
Hi Jay...
Good luck with the banjo....and a little music to help:
http://www.youtube.com/watch?v=WYRmsbEQXEg
jaylee
Re: Banjo.
Post by jaylee » Mon Aug 22, 2011 8:04 pm
OK.? A variety of answers ... 8)
From what i can find under my sink to something cranked up & backfed from the inbred...! :wink:
daveblueozzie
Re: Banjo.
Post by daveblueozzie » Mon Aug 22, 2011 8:23 pm
When i cleaned my banjo filter, i found a very small amount of brown like hard crud, i think something like caramelised oil. It was a small amount, but i found that if i broke it a little, it came out, then i just blew air through it and held it against a light to see it was clean.
Lost without my Bongo.
jaylee
Re: Banjo.
Post by jaylee » Mon Aug 22, 2011 8:30 pm
I have a small plug in the cig lighter socket compressor (Mainly for pumping up my dads wheelchair.) Do you reckon that would do the job? Just in case??!! :wink:
Am i given to understand the crud would build up on the outside??
daveblueozzie
Re: Banjo.
Post by daveblueozzie » Mon Aug 22, 2011 8:44 pm
jaylee wrote: Am i given to understand the crud would build up on the outside??
The crud was on the inside ,so it must have been slowing the fuel down a little bit. :shock:
jaylee
Re: Banjo.
Post by jaylee » Mon Aug 22, 2011 9:08 pm
As if the filter is seen as a cup, where the tea would stain?
nicstrike
Re: Banjo.
Post by nicstrike » Mon Aug 22, 2011 9:42 pm
if it was a cup , the tea would pour out through the holes!
jaylee
Re: Banjo.
Post by jaylee » Mon Aug 22, 2011 9:50 pm
No "Michael" being taken on the last question, just getting my head round which way it filters, not having disassembled this unit before... :wink:
daveblueozzie
Re: Banjo.
Post by daveblueozzie » Mon Aug 22, 2011 9:56 pm
Imagine the banjo as a tea strainer, you pour the tea through the strainer and it catches the tea leaves, (don't work with tea bags #-o )
The fuel goes through the strainer (banjo filter) and it catches any crud that the main fuel filter does not catch before it gets to the injectors.
Are you changing the fuel filter as well, if so get some injector fluid and fill the new filter with it to clean the jets.
Last edited by daveblueozzie on Mon Aug 22, 2011 10:14 pm, edited 1 time in total.
jaylee
Re: Banjo.
Post by jaylee » Mon Aug 22, 2011 10:04 pm
daveblueozzie wrote:Imagine the banjo as a tea strainer, you pour the tea through the strainer and it catches the tea leaves, (don't work with tea bags #-o )
Are changing the fuel filter as well, if so get some injector fluid and fill the new filter with it to clean the jets.
Cheers Dave... Was having a little trouble with my reasoning looking at the pictures in the fact sheet.. Sussed now.. I'm not really a tea drinker... Tastes like liquid halitosis to me!
