AFT warning bleeper
AFT warning bleeper
How does it cut out? I mean, what is the actual device (microswitch?) that causes the bleeper to stop when the roof is fully open? I presume it's located somewhere along the channel. I only ask because mine has become rather temperamental and sometimes doesn't cut out even though the roof is fully open. No similar problem with the close warning.
'Enjoy every sandwich'
- haydn callow
Re: AFT warning bleeper
you may think your roof is fully open but in fact probably just needs a little push up to turn the beep off.
- missfixit70
Could well be the microswitch, this thread (one of many) may help - http://www.igmaynard.co.uk/bongo/forum/ ... icroswitch
Might be my imagination, but I find that giving the throttle a little blip seems to help.
Ours started doing the same thing recently - found a wee shove (not too hard, just a light press with the palm of your hand) resolved it - then after reading about this on another entry foung that raising the roof with the enging running seemed to resolve it too
Jezza
- missfixit70
Roof should always be raised with the engine runnning, mine occasionally needs lowering a bit & lifting again a couple of times to get it to lock out, especially if it's been dormant for a while, raising the revs on the engine may help a bit too as it increases the alternator output with load on it.
