Brake fitting
Brake fitting
Can you confirm if kwik fit would replace brakes on freda?
thanks
Jilly
thanks
Jilly
Duchess alias Jilly the freda\bongo lover
4WD Ford Freda XLT Auto Free Top, burgundy and silver
Re: Brake fitting
Would you really trust something as important as your brakes to a company who can't spell "Quick" ?
Re: Brake fitting
Yes they could but expect to cough up bit more and they will try to quote you new brake discs aswell
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
Re: Brake fitting
Looks good,
Free brake check
Quality Brake parts in stock and ready to fit today by specialist brake technicians.
Once fitted we will replace worn out brake pads & shoes for free for as long as you own the vehicle.
You can now book an appointment online with your local Kwik Fit Centre for a Free Brake Check. Simply click here to start the process. Alternatively, call your nearest brake centre direct on 0800 222 111 today. We are open 7 days a week.
Lifetime guarantee
To ensure your brakes are always at their best, we offer a unique brakes lifetime guarantee. Once you have pads or shoes fitted at Kwik Fit, the replacement of these parts when they wear out is absolutely free to you, as long as you own the car.
You can drive in where and when it is convenient to you, no appointment is necessary and with the Kwik Fit life time brake guarantee you are sure of great value.
The examination includes the digital measurement of wear on brake pads, shoes, brake discs and drums against the manufacturer’s specifications. The aim is to provide the best possible advice to help you restore the condition and efficiency of your braking system to as near the manufacturer’s original specification as possible.
Kwik Fit Brake check takes around 45 minutes to complete and the result of this examination is recorded on a written brake report together with a quote for any required work.
At Kwik Fit, we stock Brakes to fit the widest selection of cars and light commercial vehicles, so when your brakes need attention you are never very far away from the solution. We all understand the importance of keeping your braking system working at its optimum level, so why not call in to Kwik Fit today for your free brake check. Terms and conditions may apply, ask the centre manager for details.
Free brake check
Lifetime guarantee
Re: Brake fitting
0r in lay mans terms we give you the cheapest parts for free(the pads/shoes) for life, but we then charge you lots of money for the discs, just to keep within the manufacturers tolerances of course, also for life.rita wrote:Looks good,
Free brake check
maybe a bargain, maybe not.
Re: Brake fitting
That's the same "fast fit" outfit that robbed me £800 for new pads and discs on the scorpio cosworth i had at the time (about 13 years ago)... I made the mistake of not asking how much before i said "yes just replace whatever it needs"
The fella then took the car for a "quick run" to bed in the brakes for me... I noticed a burning smell upon his return... When i checked the cars computer he'd managed 68 MPH in 1st gear!
Not bad considering he'd gone down a 30 MPH road... Good job there wasn't any speed cameras! The brakes were crap afterwards too, i should have stuck with standard Ford stuff, About £450 (fitted) from a proper ford dealer... You lives and learns!
M 80NGO
Re: Brake fitting
Just a qick scan on the web and it would appear that front and rear discs and pads come in at £120 for all the bits, so now it'll be interesting to see what kwikfit want to charge
http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 336098ea14
http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 336098e9dd
Get a written quote and if they phone you up mid job and tell you that this n that needs doing insist on seeing the old parts that they say need changing whilst they're still on the van and if you do have anything else changed ask for the old bits back.
- daveblueozzie
Re: Brake fitting
I bought new brake pads and made sure they were correct for the bongo, took them to a local garage and they charged me £5 to fit.
Lost without my Bongo.
- rhino-wayne
Re: Brake fitting
My Bongo's brakes started squealing 2 days before Stourport Bongo bash !
Shock horror panic
I took to my neared "free check" place aka Kwik Fit, they had a look & informed me I needed new Brake shoes, Calipers & discs
But they couldn't get the parts (
Called ADS (bongo specialists) & they did the job next day Discs=OK, Calipers=managed to un-seize just had to pay for new brake shoes & labour...
........................Off to Bongo Bash the next day
- mikexgough
Re: Brake fitting
personally....... NO don't go there..... that company are known to ALWAYS rip you off one way or another plus I would hazard a guess they wouldn't have a clue where to get the pads etc from....
Re: Brake fitting
Hi,rhino-wayne wrote:My Bongo's brakes started squealing 2 days before Stourport Bongo bash !Shock horror panic
I took to my neared "free check" place aka Kwik Fit, they had a look & informed me I needed new Brake shoes, Calipers & discs![]()
Called ADS (bongo specialists) & they did the job next day Discs=OK, Calipers=managed to un-seize just had to pay for new brake shoes & labour...........................Off to Bongo Bash the next day
It might be worthwhile getting your vehicles brake fluid replaced if not been done recently.
Cheers.
Re: Brake fitting
I'd avoid Kwikfit for reasons given above, but any good local mechanic (if you can find one on recommendation) should be able to do the job at v. reasonable cost (pads alone is not a complex job at all). You don't need a Bongo specialist, just an old fashioned honest competent mechanic.duchess wrote:Can you confirm if kwik fit would replace brakes on freda?
thanks
Jilly
Re: Brake fitting
+1 to that. Worth taking the time to find on of them - a rare breed and getting rarer!
Re: Brake fitting
or learn to do it your self
its a very easy simple job afterall
