Hi Everyone
Anyone know if the automatic gate should be illuminated to show the postion of the lever in the dark.
auto gear lever
georgeb
Re: auto gear lever
Yes, there is a bulb which should be on while the ignition is on. However, is is not especially bright.
- missfixit70
Re: auto gear lever
Mine only illuminates when the lights are on, worth cleaning the indicator strip from behind, hell of a lot brighter thenSimon Jones wrote:Yes, there is a bulb which should be on while the ignition is on. However, is is not especially bright.
Re: auto gear lever
You could be right Kirsty, don't have one of my Bongos to hand right now
georgeb
Re: auto gear lever
Thanks will try cleaning and check the bulb
