FLIP DOWN TV + WHERE TO FIX IT..PLEASE!
yorkshirelass
- Tribal Elder
Seems my portable 10" flat screen tv/dvd has no fixing brackets/plate. Do I need a new one[tv] or can I buy a bracket/plate to accommodate it; plus...where do people 'fix' their tv's ? I am wanting it to 'flip down, then flip back when not in use.
Fingers crossed someone knows !!
Pam
Pam
Re: FLIP DOWN TV + WHERE TO FIX IT..PLEASE!
Hi Pam,
Have a search for tv in previous posts submitted. There are some great posts detailing where and how to do it.
Daz
Daz
Daz and debs
A1tony
Its not easy to fit one if your Bongo is a flip top. If you mount it between the two front seats it would need to sit so far forward that the Police may take a dim view (ahem..) as you will be able to see it from the driving position.
I gave up and fitted 2 smaller ones in the headrests that work just fine.
Obviously if you have a tin top you might not have this problem....
regards
Tony
regards
Tony
yorkshirelass
- Tribal Elder
Hi Daz,wormey wrote:Hi Pam,
Daz
I've tried searching as I know its been on before....but I cannot find any mention ....any ideas where to look ?
Pam
yorkshirelass
- Tribal Elder
A1tony wrote:Its not easy to fit one if your Bongo is a flip top. If you mount it between the two front seats it would need to sit so far forward that the Police may take a dim view (ahem..) as you will be able to see it from the driving position.
regards
Tony
Hi Tony,
Sorry for the confusion....I meant a flip top tv...not a bongo. Yes mine in an AFT... hence the problem. Glad you got yours sorted, but such a small screen as yours...would sadly be no good for me !!
Pam
- Mickymouse
Just nipped out and took these pics of our TV.It is mounted just behind the AFT roof switch.Don't know what sort of mounting bracket it is,it was already fitted when we bought the Bongo.
The TV can be swivelled to any angle.
Mick
Mick
White 1996 P.reg SGL3 2.5D AFT Side Conversion
yorkshirelass
- Tribal Elder
Mickymouse wrote:Just nipped out and took these pics of our TV.It is mounted just behind the AFT roof switch.Don't know what sort of mounting bracket it is,it was already fitted when we bought the Bongo.
Mick
THANKS FOR THAT MICK!!!!
Its exactly what I want.........now think I need a new TV as mine just has a metal handle , like a photoframe...to stand it upright ; nowhere to fix any fittings.
Anyway, something for me to plan and save for !
Pam
Wow, thats a Big one, mine is only a 10 inch. Great photos though.
Hi Daz,
Pam
Pam, try pimp my bongo or the converting to campervan thread.
Daz
Hi Daz,
Pam
Daz
Daz and debs
There is a plastic cover at the back of the bongo near the rear boot light on the roof that reveals a thread enough to attach a very small bracket to if you get the right sized nut.
Daz
Daz
Daz and debs
