OUCH
that much for the tensioner!!
We got our bongo with 82,000kms on it in Sep 2010......we've done just shy of 19,000kms since we've had it.
So, the cambelt was changed on import and when it was repaired in that Scotland.
The reason that the seal was replaced was that the other half noticed a big oil slick after the bongo had been parked up overnight.
So when we took it to the garage after a frantic 24hrs of searching (cheers to BF and Billy Bongo for sorting us out). When the garage had the bongo on the ramps, it turned out that the area around the seal had been 'filled' with some gunk. The garage owner was disgusted that such a bodge job had been done - as for a time line as to he couldn't say when the 'fix' had been done.
My intuition is that it was done in Japan to get it through the auction process; reason being is that when the cambelt is changed if the seal was seen to be leaking it is a very quick fix as the plate is off and the mechanic is there working on the belt change. The seal was only £25 inc postage, so I seriously doubt that the dealer and garage would scrimp on that!
Currently if it turns out to be any of the rollers with the belt thats an approximate bill of £400, with that tensioner you mentioned thats another hour of labour and the part, bumping the bill up to approx £700 in total.......yesss (pumps fist in air with joy!!)
AAAGGGGHHHH
I hope not, as that will have pushed the garage bill for our bongo for the year to almost £1400 ......not on, even if I loves him to bits.
